Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima tumble drier condenser has F 10 error code
What dose F 10 error code mean, I cannot find my hand book
  • k_manger Jan 19, 2009
    I do not have a multimetre, futhermore your expalnation makes no sense to me. I have lost my hand book. I have not had to use it before. This is the first time the machine has failed.
  • Hotpoint Master
  • 3,463 Answers
Error code F10 means common feed of heater or thermostat open circuit.
You need to test the thermostats and the heater element for continuity.
You need a multimeter to do this, assuming you know how to use a meter,then set it on the ohms range for continuity, remove one wire from each stat, and test with meter across terminals of stats,
You should get FSD if stats are o/k.
If you don't, then you need to replace both stats, even if only one is faulty.
It is unlikely to be the element that is faulty, as they rarely fail.
Plz rate my solution.
Thanks
Posted on Jan 12, 2009
  • Barry Coates
    Barry Coates Jan 19, 2009
    Hi.
    I was wondering why you found my solution inappropiate for your problem
    You asked what F10 meant, and I told you what it meant, and a detailed explanation of what to look for.
    The code is listed in the Hotpoint error codes on the web.
    I look forward to your comment.
    Thankyou.
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
8KG ULTIMA TCD 980 condense tumble dryer : the excess water isn't going in the bottle
How do I change the belt on a Hotpoint condenser tumble dryer
Aug 25, 2013 | Dryers
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
829 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
