Question about HP Computers & Internet
How to connect my computer to hugesnet with a eithernet cable
  • HP Master
  • 27,725 Answers
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Posted on Dec 08, 2012
Can get router to connect to Internet
Cathy, your router does not connect to the internet, your modem does. Are you trying to use wireless, or is it hard wired like using an eithernet cord? If so then make sure the eithernet cable is hooked up properly and that it is goodIf it is good then try to connect your modem directly to your computer by using the eithernet cable. If that works then you know that the signal from and too your computer is working properly. Next go to your control panel and open network and sharing center. Go to set up a new connection. If that doesn't work then you might suspect a defective router. By the way has it worked before or is this a new setup?
In order to help you through this you need to be more specific with what is going on with your system. What brand of router is it? Depending on what brand there is a web address you can use to be able to access your modem.
Good luck,
Marty
Jul 19, 2014 | Computers & Internet
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
I need help installing a bountiful wifi router to hugesnet internet_99_86@yahoo.com
Could you be more specific to the problem that you are experiencing?
Did you plug the hugesnet network side to the WAN port of your bountiful wifi router?
Are you able to get a DHCP IP address from the bountiful wifi router?
Are you able to get a WAN address from hugesnet?
Mar 01, 2011 | Computers & Internet
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my...
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Nov 02, 2010 | Dell (0E828) for Latitude C610 Modem
I need help to connect my Linksys WRT54GS router.
you connect your caple from your provider and all connections to your station then start setup by going to the browser and typing 192.168.2.1 for setup you can download a step by step instruction from LINKSYS
Nov 07, 2009 | Linksys Wireless-G WRT54GS Router...
My wireless router says its connected but local only no internet and i know the ether net cable is good bc i can use the cable but not the wireless router
You can plug your computer directly into the modem bypassing the router if you wish.
You have a commercially prepared eithernet cable? I doubt it is faulty unless you have abused it.
A tester for eithernet is available at the big box store for about $50.00 if you need to test it. (buy another cable instead - save $40.00)
Oct 18, 2009 | Computers & Internet
Cannot connect thru the ethernet cable. Can only connect wireless
The solution that I received yesterday was given to the tech that had worked on my computer and she said that she would follow the information and believed that everything would be working nornally.
thanks
May 14, 2009 | HP Pavilion dv9000z Notebook
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
I have a Linksys router and it really dosn't tell me a lot about hooking it up! Can anyone help? MDL# EZXs55W It is a five port. The tech connected the cable and the eithernet cable to the modem. I tried...
Great !
But if you have trouble installing the cd, follow these instructions:
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | Computers & Internet
How to conect my westell 327w to my cable box
looks like this 1)cable modem
2)eithernet cable to westell gatewas port 1
but before you do this lob into the properties manager with just one computer connected directly to the gateway any port but 1... cancle dsl connection go to advanced wan click wan and from drop down choose bridge or on pop up which ever is easier.. then inable wan on eather port 1 on the drop down... Now config the rest of the settings the way you choose them and when your all done plug the eithernet cable into port 1 and let the cable modem sync with the gateway......
Jan 24, 2009 | Westell Wirespeed VersaLink...
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
