Question about Sony KDL-46S4100 46 in. LCD TV
Keeps popping the breaker when we turn it on - Sony KDL-46S4100 46 in. LCD TV
  • Sony Master
  • 933 Answers
If it is tripping the breaker in your electrical box? or the breaker on a plug strip/surrestor? Or are we referring to the fuse inside the TV?
Posted on Dec 08, 2012
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
Why does my microwave Keep popping circuit the breaker?
It will pop the breaker if the breaker is overwhelmed.
Jul 29, 2014 | Microwave Ovens
One breaker is popping what to do
You have a wiring problem on that circuit. The circuit is doing it's job. Call a qualified electrician.
Apr 22, 2013 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
My furnace will not turn on it is a intertherm feh 015ha. Every time I turn on the breaker the fuse pops really loud in the furnace and turns it off again. How can I figure out what is wrong if I cant even...
I would suspect your evaporative motor (located in the furnace) is shorted.
To prove it - just disconnect the electrical wires to the motor and turn the breaker back on.
Most likely the breaker will stay on - which will tell you for sure that the motor is shorted.
Note: it's possible that the capacitor on your motor is shorted - but I doubt it. i would bet on the motor. In any event - you have a 'direct short' which is causing your breaker to pop, and I would bet it's the motor.
If it isn't the motor you will just need to find the 'short' to keep the breaker from popping.
Aug 06, 2011 | Heating & Cooling
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Model arp-900e wont start keeps popping breaker
Sounds like you have a short or a groud in a fan motor or compressor motor. You can unhook one component at a time and turn it on after each component is disconnected to figure out which one is grounded.
May 03, 2010 | Royal Sovereign Portable Air Conditioner
Keep poping the breaker on instllation
Check your wiring for short circuits. If you turn the switch on and it pops it may be in the switch box or up in the fan box. Also make sure the fan blades spin freely. A motor overload or short circuit would be the only reason for the breaker tripping immediately.
Jan 10, 2010 | Hunter Sontera 52" Ceiling Fan with...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Breaker Keeps Popping
there is something wrong inside the saw.
if you are trying different amperage breakers ( trying a 15 AMP breaker and then trying a 20 AMP breaker) or if you are trying all 15 amp breakers try a 20 AMP
Jun 28, 2009 | Mk Diamond Benchtop Wet Tile Saw
Sony KDL-46S4100 46 in. LCD TV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
