Electrolux EWN 14991 washing machine - anti flooding device has activated - says to check inlet/drain pipes - have done but cannot see any problem - I did wash down some stoggy washing powder that had built up in the drawer - could I have blocked something ? How do I get the machine to start or finish the cycle, the pump continues to run even when switched to off but if I turn to a programme it messages flashed again.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: electrolux insight EWN 14991 W
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Aug 19, 2011
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Machine is stuck on drain
You did not specify which model of the washing machine you have. It can be:
- a blocked drain pump, filter, drain hose..... and the pressure switch can not switch to "empty" position.
- faulty pressure switch
- activated anti-flooding device
Dado
Sep 01, 2014 | Electrolux Washing Machines
Anti flooding on aeg 64840
Problem was answered earlier. Please check the water level sensor, check the line , remove and reset. Also check for blocks in the INLET and DRAIN filters.
Jan 20, 2013 | AEG Washing Machines
Problem with electrolux washing machine
draining pipe its too low. check this link:
http://applianceguru.com/washers/drain-min.jpg
Aug 26, 2012 | Electrolux Washing Machines
I have a electrolux Insight EWN 14991 W which I have for over 2 years. The problem is that it keeps coming up to make sure door is closed properly which it is. It stills refuses to go through a cycle. ...
It sounds like the micro door switch could be intermittently faulty. Switch unit off from power supply and unplug for 10 minutes. Restart. If problem reoccurs then you will need a service call.
Jul 26, 2011 | Electrolux Washing Machines
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
What do you do if the Miele washing machine's check drain and inlet light is on?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Feb 15, 2010 | Miele Novotronic Premier 500 Front Load...
Both red lights flashing for check inlet and drain.I have checked both and they are O.K.I have also checked filter.
Feb 09, 2010 | Miele Novotronic Premier 500 Front Load...
Stopped
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
