Question about Samtron Computers & Internet
Monitor Samtron after 10min. looses contact with computer
I am using your SAMTRON 73V flat monitor 4th year. Several month ago the monitor did start to block after more than one hour time of use. The time of proper work did gradually drop down, to recent about 10 minutes, what is to short for doing anything. The blocking of the monitor appears as: moving round the screen a warring window with message 'not optimum settings, use 1280x1024x60Hz' by total lack of contact with the computer.
It is not possible to change actual settings using monitor keys.
After switching off the terminal for not less than about 10 min. and resetting the computer, the terminal can work properly next 10 minutes.
The optimum settings (shown in the warring window: 1280x1024x60Hz) of the terminal adjusted from Windows control panel do not allow to get proper work of the terminal in any future attempts.
The workshop:
VIDEO SERVICE
os. Pod Lipami 1d
61-628 Poznan, Poland
e-mail: avts@wp.pl
tel: +48 61 8205688,
told me few hours ago that they are unable to find proper integrated circuit to be replaced. They would expect to solve this problem if you send the electrical scheme (diagram) of this monitor on their address (regular or e-mail) given above.
Boleslaw Porankiewicz
os.Rzeczypospolitej 90/7
61-392 Poznan, Poland
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
Posted on Jan 12, 2009
2 Suggested Answers
SOURCE: monitor looses contact with computer
check the video card if it is properly inserted.
Posted on Jan 13, 2009
I am a technician.My Samtron 56 V moniter dead. Some time switch on when power is connected after 10to15 minutes. Please give a solution.
If you have Samtron 56 V monitor that sometimes switch ON for 10 to 15 minutes, then it is a signal of some internal device fault which needs to be rectified from certified hardware technician from monitor manufacturer service center itself. It is recommended to directly contact Samtron for hardware replacement if it is under warranty or ask to repair it.
GuruAid.com
Jun 24, 2016 | Samtron Computers & Internet
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Need Graphics Drivers for Samtron SC-423ps model
For the monitor? In 10 years I've never needed drivers for a monitor, I think you need drivers for your display adapter, check the maker of your computer's website / support - download section for drivers.
Mar 31, 2009 | SAMTRON 55V 15" CRT Monitor
Black screen with box of 'Suggested resolution 1280 x 1040 60Hz'
The Samtron 73V has a maximum resolution of 1280*1024, are you running at that resolution ?
Mar 15, 2009 | Computers & Internet
Monitor looses contact with computer
Jan 12, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
386 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
