Question about SVP 2.8" Dual SIM Quadband Q70 Black Touch Screen Phone Unlocked
How do you remove the back from the SVP Q70?
I can't figure out how to get the back off so I can insert the battery and the sim cards.
Hold the phone upside down (screen facing down). Then using 2 or 3 fingers placed directly on top of the backcover, slide the back cover down (slide it in a direction from the camera toward the SVP logo. Its hard to slide, so push down and slide as hard as you can and the back cover should slide open.
Posted on Dec 31, 2012
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
Mar 29, 2014 | Samsung Galaxy Cell Phones
Remove back fom svp q70
yes how u expect the phone to come on sweetheart
Mar 01, 2013 | SVP 2.8" Dual SIM Quadband Q70 White with...
How do i adjust volume on SVP Q70?
Call to your cell phone, when it rings touch the screen on speaker, then adjust volume.
Jan 26, 2013 | SVP 2.8" Dual SIM Quadband Q70 Black Touch...
How to open the SVP model Q70 phone to put in the battery and SIM card? Does it slide? Can't figure it out.
Use your thumb to apply slight pressure to the top edge of the phone (in between the camera and the speaker). With your thumb, push the back cover towards the bottom edge of the phone. Pull the cover away from the phone as shown in the third image.
Jan 12, 2013 | SVP 2.8" Dual SIM Quadband Q70 White with...
How do you insert the sim card
Take out the battery, the is a sliding metal bracket that slides down and pops up. You'll insert the card in the bracket and not the phone, then reclose the bracket and slide it up till you feel it click and then your done.
Dec 02, 2012 | Cameras
Sim card not ready
Try going to storage in the settings menu. See if it says mount or unmount SD card. If not just take out sd card n turn off phone. Turn on. Look in menu, see if phone recognizes there is no sd card. If so, good. Turn phone off. Remove battery 5 seconds. Insert battery and sd card. Turn on phone. Allow total boot process before manupulating phone. Go to contacts. If it doesn't read the sd card automatically then press add contact. See if it has add from sd card
Sep 27, 2012 | Nokia E71 Smartphone
How to insert the sim card
Remove the back cover of the phone, and remove the battery, laying it aside on a clean flat surface. From there, there's normally a little diagram that's in the shape of a rectangle with a triangle facing the interior of the device. This is a the SIM tray. Place your SIM card face up into the device, and re-insert the battery and turn it back on. And you're good to go!
Unless of course you have a Verizon phone, as they do not have SIM cards in them.
Hope this helps!
Jul 22, 2011 | Cell Phones
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
SVP 2.8" Dual SIM Quadband Q70 Black Touch Screen Phone Unlocked Logo
576 people viewed this question
Top SVP Cell Phones Experts
Computer Repairing
Computer Repairing
 Mikey
Mikey
Are you a SVP Cell Phone Expert? Answer questions, earn points and help others
