Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator is not cooling
Freezer is working but the refrigerator is not cooling
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 08, 2012
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
might sound stupid but is the fridge controled by a separate thermostat inside the fridge
Posted on Jun 26, 2008
SOURCE: Refrigerator is barely cooling, but freezer woks fine.
Sounds like a defrost problem. First though, check your settings that they are in the correct spots where the owner's manual tells you they should be. IF that is not the issue, next, can you look in the area of the back wall of the fridge to see if the condensor coils are all iced over? You may need to remove the rear inside panel to see them. No hard, couple of screws and your there. This is most commonly caused from little people or our beloved spouse (never us!) leaving the fridge door open a smidge overnight or through the day. Another common problem is after the holidays when someone other than yourself tries to stuff the 50 pound turkey in a 20 spot leaving no room for the door to shut. As a result, the chilling function will go into hyperdrive to keep cooling and eventually ice over and become very inefficient at cooling in the fridge. Even the freezer is effected, but it is not as easy to notice. Here's what to do. Once you find the large area along the back wall of the fridge that contains the frozen over coils, you will want to unplug the fridge and get that ice out of there completely. Using hot water and a catch basin to catch the water you pour over the coils, continue this until the ice is all gone. Make sure your settings are back to normal settings as per owner's manual and plug in. Should be all better now.
Posted on Jan 08, 2009
  • 103 Answers
SOURCE: bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
Posted on Jun 03, 2009
projdoc
  • 2236 Answers
SOURCE: Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator not cooling freezer works fine kenmore 106.55522400
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Freezer working ok, but the refrigerators not working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
Fan in freezer area does not turn on, refrigerator no cooling, freezer works fine
heatman101
Jan 18, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Freezer working - refrigerator not cooling
heatman101
dtiurt7
Oct 27, 2009 | Maytag MZD2766GES Side by Side...
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Not cooling but freezer works fine
heatman101
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Not cooling refrigerator part
heatman101
fgjkgd
Dec 03, 2008 | Roper RT21SKXLQ Top Freezer Refrigerator
Top refrigerator part not cooling, bottom freezer and fan working
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
