Question about Kenmore Washing Machines
Remove top from washer kenmore model 11042182200
How do I remove the top from the kenmore model 11042182200 washer?
Amigaman
  • 248 Answers
SOURCE: How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Posted on Nov 22, 2007
Joe Onley
  • 363 Answers
SOURCE: kenmore model 110 will not start drain cycle-top load washer
If the machine agitates, you probably have a bad pump. This is pretty straightforward repair, and I'm sure I can help you if you think you can do this yourself. Follow this link to a previous explanation on cabinet removal and you will find the pump right in front of you when you get the cabinet off. The part is relatively inexpensive to obtain from a local appliance part store. Changing is very simple. Hope this helps you :)
http://www.fixya.com/support/t2827272-kenmore_washer_model_23922200_not_spin
Posted on Oct 01, 2009
  • 254 Answers
SOURCE: Kenmore washer model 110.24872300, need to romove control panel
if u got rooom just tip the unit back and get acesss underneath it will be a lil bit tighter space to work but will save you the time and hassle of removin the concole......... u will need a part # 285753A- whirlpool motor couplling.... most those consoles remove though by screws on backside corners or front corners, remove those tilit concole back remove brass brackets, wiring lid switch, pull cabinet off hope this helps
Posted on Feb 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: how to remove top from kenmore washer
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer Tub appears top be off center after move upstairs
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Posted on Sep 15, 2010
Kenmore model #22622100 top load washer. My question is our washer has a sour smell and we have pulled it out from the wall. We are wondering how to take the top off.
First, see the Sears parts site for your washer with diagrams and parts lists. Always a good reference tool.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022622100/0582/0153200?pathTaken=&prst=0&shdMod=11022622100
Next, see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
As a final reference, see the following Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Feb 12, 2011 | Kenmore Washing Machines
I have a Kenmore Elite top washer and was wondering how to lift the top to clean
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Jun 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Replace mixing valve
If this is a Kenmore top loader such as the one pictured, you need to remove the exterior washer case in order to access the mixing valve. DO NOT attempt to remove the back pnel as these washers are not designed to have the back panel removed. The following link explains step-by-step how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
I could not find an exact match for the model number you provided, but most Kenmore top loaders are configured the same regardless of features.
If you have any questions about this repair, or if your washer configuration is different from what I have described (i.e., if this is a Calypso, Cabrio or Oasis), please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Apr 02, 2010 | Kenmore 23822 Top Load Washer
How to remove top of kenmore oasis washer to replace lid lock mechanism
5
6
7
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
How do you remove the top on a Kenmore top loading washer to replace the lid switch?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet and gain access to the switch.
Nov 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
I need to remove the back panel on my top load kenmore washer
5
6
7
Jan 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
