Question about Westinghouse Televison & Video
How to obtain code for ATSC tuner activation for westinghouse LD2240
LD 2240
  1. activation code 6160y04401296
Posted on Aug 03, 2014
5 Suggested Answers
  • 1779 Answers
SOURCE: need ATSC Code to activate
There is no such thing. You either have an ATSC tuner in your set or you don't. They are in all sets today if you bought a new one. If your using an outside antenna, that's what that tuner takes care of for you.
Maybe if you explain further the problem you are having I can supply you with the answer.
Posted on Dec 04, 2010
SOURCE: I need to get an
http://wdsupport.net/wdeonlineservice/tunercode.aspx
Posted on Mar 16, 2011
SOURCE: Obtain Tuner Activation Code Serial Number:
Westinghouse.com/support then go down and click tuner activation put your serial number in to your right and hit enter and you got a code
Posted on Dec 05, 2010
westytech
  • 120 Answers
SOURCE: Need activation code for Westinghouse flat screen
You should be able to use code # 71229.
Posted on Jan 25, 2011
Reset code for westinghouse ld-2240 tv
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 10, 2016 | Westinghouse LD-2240 22" LED TV 1920x1080,...
Cual es el codigo de acceso para canales de tv LD-2240
Codes are stored in the remote. A Westinghouse remote should be able to control your TV directly. If you are using a universal remote, you will have to perform a code search to find something that will work.
Jan 15, 2016 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
What is the universal remote code for Westinghouse LD - 2240
hi! i have here a couple of codes for you! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Jul 29, 2015 | Westinghouse Televison & Video
Códigos de acceso mediante antena ATSC
Necesito codigo de acceso a canales TV westinghouse.
Modelo VR-3730
Serie: 6561V14301725
Apr 13, 2015 | Westinghouse LD-2240 22" LED TV 1920x1080,...
How do I get the service code for my tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jan 01, 2015 | Westinghouse Televison & Video
Need code for westighouse ld2240 serial 6616121805787
Just guessing you want to control your Westinghouse TV with some kind of remote, perhaps a programmable one. The codes are sent from the remote to the TV, therefore we need to know what brand of remote you want to use
Jan 17, 2013 | Westinghouse NEW 22" Class / LED / 1080p /...
Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
Sep 14, 2012 | Televison & Video
Obtain Tuner Activation Code Serial Number: 6200Y04102884
Dec 05, 2010 | Westinghouse Electric LD-2655VX 26 in. TV
I just bought a LD-325 Series TV. I need to get a tuner activation code. can you help me
Navigate to the following URL: http://wdsupport.net/WDEOnlineService/tunercode.aspx . Then provide your model and the serial number provided in the Setup Wizard's "Obtain Tuner Activation Code" window as well as the type of input (OTA or QAM). Then when prompted by the Setup Wizard, input the activation code using your HDTV's remote control and press enter. Your channel scan will begin. Alternatively you can call 1-800-701-0680 and navigate the voice mail system.
The website can either display the code or send you a copy by e-mail. I strongly suggest that you print out the code and save it. Keep it with your manual and warranty documents if you can keep everything together. Then if you have to reset the TV to the factory settings, you will be able to reuse the code.
I hope this helps.
(for more information see page 22 in the manual. For a digital version, go here: http://westinghousedigital.com/products/led/32-40/ld325/ . The link for the User's Manual is on the left side of the page.)
Nov 14, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
2,334 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
