Question about Toshiba PORTEGE R830-10Q
Can anyone tell where the jumper is on a portege r830-10q cant find it anywhere trying to reset bios password
Stakanoff
  • 69 Answers
SOURCE: Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Posted on Mar 22, 2009
  • 5 Answers
SOURCE: i cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Posted on Jul 08, 2010
SOURCE: how to Toshiba Portege 7020CT Laptop bios password
dear sir i like to inform you that i have 1 laptop the model no:portege 7020ct this is now not back up why i am not idea please tellim to me any idea about the laptop for back thanks and best regards
from Thoufeek UL.
Posted on Jan 30, 2011
ratonxi
  • 112 Answers
SOURCE: i forget my bios password for Toshiba L500D..is
If you can access to Windows Vista, it's as easy as to reflash the bios for your laptop-it will reset the bios password automatically. You can download the bios to reflash it from: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
A) Turn the laptop off if it's on.
B) Disconnect the AC adapter, and remove the Battery
C) Turn the laptop over, remove the Memory Module Compartment Cover. (1 screw)
D) Remove all ram memory modules. Lay them on a non-static surface.
E) View this photo,
http://www.csd.toshiba.com/content/support/bulletins/su2044812/012-Mylar_film-06.jpg
F) With the computer situated as in the photo above, grab the Mylar film by the upper left corner.
Peel it back to the Right. DO NOT peel it off!
Just peel it back far enough to expose the B500 solder pads.
http://www.csd.toshiba.com/content/support/bulletins/su2044812/009.jpg
G) Attach a 4 inch piece of tape to the underside of the Mylar film, as shown in the above photo.
(Do not remove the Mylar film because it might be difficult to reattach properly later.
It has to be in THAT particular position when you are done)
H) Inset one of the memory modules into the inside ram memory slot. This is Ram Memory slot 1.
The ram memory slot that is closest to the BOTTOM.
(There are slots for two ram memory modules. One at the bottom, one at the top. The top is closest to the Memory Compartment Door)
I) Secure the tape to the laptop body, to keep the Mylar film from touching the solder pads. (B500)
J) Reconnect the AC adapter. Plug the adapter into power.
Short across the tow solder pads, (B500) with a pair of needle-nose pliers, or a flat bladed screwdriver.
K) While continuing to short the solder pads, turn the laptop on, and continue shorting the solder pads until the Toshiba logo disappears.
If the BIOS password has been successfully removed, the laptop will not present a BIOS password prompt before Windows starts.
L) Shut down Windows normally making sure the laptop has completely turned off.
M) Disconnect the AC adapter
N) Remove the ram memory module, and remove the tape. Reposition the Mylar film back into place.
O) Reinstall all ram memory modules, reinstall the Memory Compartment Cover.
Reinsert the Battery, and the AC adapter.
P) Restart the laptop to verify the BIOS password prompt no longer appears.
If it does repeat this procedure beginning with A above.
MAKE SURE you are wearing an ESD wrist strap, and have the alligator clip attached to a good ground!
Example of an ESD wrist strap,
[HDD password prompt comes up?
Press the spacebar and press the Enter key ]
Posted on Feb 02, 2011
  • 111 Answers
SOURCE: remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Posted on Aug 20, 2012
How to reset bios password on toshiba portege m200 2001
Open CPU Cabinet's case and look for button cell of coin size on the main motherboard(circuit board) and push the pin with holding the button cell, the cell will come out. This will power off the BIOS memory and the BIOS will reset.
Oct 18, 2012 | Toshiba Computers & Internet
My nephhew just bought a gateway w350a t series laptop at auction ,the bios is password protected,does anyone know where the cmos battery is ,i cant find it anywhere. i took off all accessable covers and...
The CMOS battery is attached to the underside of the motherboard. you will need to carefully disassemble the entire laptop to access it. If there is a bios password there is no way to tell if there is an issue with the HDD. I would start with removing the CMOS and then resetting the Motherboard using the reset jumper. You need to look up the board and find where the reset jumper is, probably through a web forum or the manufacturer website. after resetting and replacing the battery, you may still run into issues...the password may be set through a TPM chip. This chip stores the security settings in flash memory. The jumper may reset this also, but I am not 100% on that.
Jun 19, 2011 | Gateway Computers & Internet
I have a toshiba portege m100 with a bios password set that i need to bypass. toshiba want 80 quid just to look at it. some sorces say short clr1 jumper but i cant find it on my machine. please help.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
Feb 26, 2011 | Toshiba Portege M100 Notebook
Cant boot up my toshiba lap top. it comes up asking for the BIOS password then shuts down after 3 tries! have tried all the F keys, shift key and removing battery!
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Jan 22, 2011 | Toshiba Portege S100-S1133 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
Bios harddisk password forgotten ,
Press fn + ctrl + esc on post screen, removing the batery does not work on new acer computers. Or try downloading bios_pw.exe and run it.
Sep 24, 2009 | Computers & Internet
I have a Toshiba Satellite A105-S4084 and its locked because i dont know my Built in HDD password
well,someone put a hdd password you need to chuck hdd and get a new one once a hdd password has been installed you will never know what it is and there is no way to over ride it unless you use a
magnet and kill whole hdd , then it is hard to write windows on it again , only choice  lala linda
Jun 15, 2009 | Toshiba Portege S100-S1133 Notebook
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Bios password for toshiba laptop needs reset
Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Feb 14, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba PORTEGE R830-10Q Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
