Question about Epson Office Equipment & Supplies
Epson l100 printer blinking on power cleaning. how to solve the problem?
Poor color printing due to clogged printer head. After three times of normal cleaning the print check lines were still broken. then forth time applied for power cleaning. while cleaning process the red light started blinking and it could not stop. no printing job can be done due to blinking red light. How could i solve this?
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
El Duderino
  • 47 Answers
SOURCE: Flashing Lights on HP 690C - Won't Print
Hi Stev, First I know this is going to sound strange but have you disconnected the printer cable from the printer itself? (not the computer) If not try unplugging both the parallel and power cables for 30 seconds, then when you reconnect and power up hit the resume button. I've seen problems in the past where a job was killed like that and the printer would not work until the parallel cable was removed from the printer. The light pattern you describe, resume light blinking with the power light on, can mean any one of the following things on that model HP. 1. Top cover is open. Open the top and make sure there is nothing keeping the cover from closing all the way. Don't forget to check the underside of the cover for something stuck to it. Close the top cover. 2. A print cartridge is missing or an incorrect print cartridge is installed. Install the correct print cartridge. AND/OR Verify that the print cartridge is properly snapped into place. Close the top cover. 3. Printer detects an out-of-media condition. Load media in the lower (IN) tray and press the Resume button. 4. Media is improperly loaded. Remove media from the IN tray, re-square the stack, and reload. Make sure that the media-width adjuster and media-length adjuster are against the stack of media. Make sure that media is not buckled in the IN tray. Verify that the media-width adjuster is along the left edge of the tray and is pushing the right edge of the media against the right wall. 5. The printer timed out waiting for a form-feed command. Press the Resume button. The page will eject from the upper (OUT) tray. 6. Printer detects out-of-ink condition. Replace the print cartridge and press the Resume button. 7. Dirty Cartridge Contacts Use a clean foam-rubber swab or lint-free cloth slightly dampened with water. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) Locate the copper-colored circuitry strip on the back of the cartridge. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. Unplug the power cord from the printer. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, contact the HP Customer Support Center listed in the printer's User's Guide. Plug the printer back in and try printing again. 8. Printer detects paper in the paper path. Turn the printer off and open the top cover. Make sure that paper is not jammed in the printer. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides) and make sure that nothing is stuck under the paper sensor, perhaps by blowing under the sensor. Close the top cover and turn the printer on. Try printing again. If none of this helps let me know and I'll see what else I can dig up on the problem. El Duderino
Posted on Nov 17, 2006
Soulvisitor
  • 1113 Answers
SOURCE: missing dot in all colors
Yes your print head is clogged,
Ive tried a few times to refurb these particular heads with very poor results, we change them under warranty but not worth while otherwise,(150aus$) 90% of print quality faults I see I can put down to inferior ink being used threw mechanisms. There is also a power purge in service mode that pumps 1/3 of each ink cartridge threw machine and dumps it but it fails to repair missing dots most times too.
 Ive also seen people with nothing but the best ink used get long life out of machine, In my eyes it is cut and dry with recycle products there is a cost in the savings,
Inks have many different thickness, stability's and flow charactistics more than just pigment or dye being the issues causing problems blocking microscopic little holes.
Yes there is a limit to cleaning cycles it is called the waste ink counter, it stops machines function eventully before overfilling of the waste ink pads occur, I usally see the print head dead before this occurs otherwise it is a  very cheap new waste box replacement and waste counter reset im not sure of life in pages they count it in dots produced
Posted on Oct 17, 2007
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
issy2
  • 460 Answers
SOURCE: Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Posted on Sep 09, 2008
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
Nov 03, 2010 | Brother Multi-Function Center MFC-240C...
Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
  • Print a Print Quality Check Sheet.
    1. ress the Ink or Ink Management key on the control panel of the machine.
    2. Press the up or down arrow key to choose Test Print and press OK.
    3. Press the up or down arrow key to choose Print Quality and press OK.
    4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
  1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
    (B) Most of the short diagonal lines are missing from one or more color blocks:
    (C)Some parts of the short diagonal lines are missing from one or more color blocks:
  3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
  4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
  5. The display will then show Start Cleaning? Yes No.
    Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
  6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  7. Repeat the cleaning and the quality check process following the Step 4-7.
  8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
    • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet
    • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times).
    • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times).
    Press Stop/Exit.
Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
Poor print quality, was OK but colors are very faint on the paper, everything checks out OK in the maintenance programs.
Hello there:
this is normally due to a dirty print head or the nozzles is clogging up
If you have ran your maintenance for the print heads and cartridges several times at least 4 in a row and this still does not clear up and you have tried to get new ink cartridges.
Go to your local printer supply center like office depot or staples and get the print head flush kit this is a specially formulated liquid that you install and it flushes out the print heads and gets all of the ink that has built up in the system out and gets the print heads cleaned it cost about 6 bucks but well worth it
Hope this is very helpful for you
Best regards Mike
Jan 19, 2010 | Dell 1320c Laser Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer has completely quit printing color with new ink installed
In order to determine whether this is a hardware or software problem there are several steps you can take:
1.Download and install the most recent printer driver from Epson
2. Try printing out the nozzle check pattern using the Maintenance Utility. This bypasses the printer driver and allows the printer to use all cartridges to print out the patterns. This will indicate whether there are clogged heads and whether or not it will print color at all. Gaps in the patterns indicate clogged heads and you need to run the Head Cleaning utility once or several times.
3. If you get color patterns from the nozzle check (whether or not the patterns are full or have parts missing) you need to check to see if the default settings for the printer have been set to "Black Ink Only". Right click on the printer icon and select "Printing Preferences". Click on the "Advanced" button in the lower right corner and after the popup, look on the left side and see it the "Black Ink Only" box is checked. If so, uncheck it and while you are there uncheck the "High Speed" box as well. This way you don't have to deselect it in the printer dialog each time you print, especially if you are looking for a quality print each time.
4. Try the printer on another computer if you get color during the nozzle check to see if the software is corrupt on your computer.
5. If you get no color patterns at all when doing the nozzle check, it would appear that you have a hardware problem within the printer. It would be unlikely that all the colors would fail at the same time due to severe head clogging.
Hope this helps in some way.
Oct 07, 2008 | Epson Stylus C86 InkJet Printer
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
1,066 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
