Question about Hotpoint Washing Machines
Hotpoint HVL 211 won't start programme
When I turn on the machine and press start the the wash light comes on but the programme doesn't start.
3 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: bosch classixx 1200 washing machine.
Before you investigate the fault, try unplugging the machine at the mains for 20 minutes. This MAY reset the problem and all will be well. If that fails, then read on:
The flashing lights are an error code. You will see that there are a series of rapid flashes followed by a pause and then the series of flashes will be repeated, this is the error code being displayed. If you count the number of flashes being given then you use that number to correspond to the fault code, for example, three flashes would be fault code 3.
Fault Code 1 notlit.gif notlit.gif lit.gif Door open after program has been startedThis error code may well not show up for a minute or so after you actually go to start the washing machine but the door can be closed and the program restarted.
If the error persists there may be a fault with the door locking mechanism or door latch.
Fault Code 2 notlit.gif lit.gif notlit.gif Water intake has failed
Error after more than 10 minutesa failure of the water inlet valve or the water supply itself has been cut off somehow. This can be due to the water valve or supply as stated but it may also be worth checking the filters in the fill valves to ensure that they are clear.
Fault Code 3 notlit.gif lit.gif lit.gif Heating time exceeds 105 minutesThis would ordinarily indicate a fault with the water heating element or, certainly, the water heating circuit as the washing machine is indicating that it has failed to reach temperature.
The error can be caused by faulty wiring, the heater as stated, low voltage or even a calcified heater has been known to generate this error code.
Fault Code 4 lit.gif notlit.gif notlit.gif Takes longer than 6 minutes to drain.Very often you will see this error if the filter is blocked or obstructed or the drain pump is jammed or faulty.
This error code can also be caused by the pressure sensor being blocked by overfoaming from overdosing detergent or using a poor quality detergent as well as a pressure switch or sensor failure.
When this error occurs the program is aborted as it is considered to be a "fatal error" without any attempt to drain the washing machine.
Fault Code 5 lit.gif notlit.gif lit.gif NTC thermistor open circuit or short circuit
Self explanatory really, either a faulty NTC or wiring. The washing machine will complete the program but will not heat.
Fault Code 6 lit.gif lit.gif notlit.gif Unexpected heatingThe machine has attempted to heat at a stage in the program where it should not.
Fault Code 7 lit.gif lit.gif lit.gif Fault detected in motor or drive circuit
Very often you will see this error if the carbon brushes or the motor fails.
This error code can be generated by no tacho reading from the motor (the electronics cannot see the tach generator of the motor), a triac fault or short circuit or a faulty reversing relay on the control board. The washing machine will try to start the motor but after several attempts the program will be aborted with this error code which is again consider to be a "fatal"
Posted on Jul 05, 2011
  • 251 Answers
SOURCE: washing machine won't go thru spin cycle. Lid
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Posted on Jul 15, 2011
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
Hotpoint WMA33 washer- The machine was in a final spin after a 95 degree wash when the power to the house was tripped by the washing machine, since then the machine will not start, all the lights come on...
Possible the surge would have made some changes in the main processor memory or damaged the processor. You can shut down the washer and remove the plug for few hours. press down all the panel buttons to drain all residual voltage on the board.
If the same fault repeats then it is possible there are errors on the board.
Jul 25, 2012 | Hotpoint Washing Machines
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
