Channel unavailable message on Panasonic recorder
Have this problem intermittently. Not able to get any channels. The message..channel unavailable come up all the time.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
What is connected to it for signal?
If there is a box in the line unpower it and this unit for a few minutes and then power both back up--it cannot hurt and very well may help.
Posted on Dec 07, 2012
Testimonial: "Many thanks! I had done that before when dealing with the same problem but forgot!"
  • 47 Answers
SOURCE: Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Posted on Apr 05, 2008
  • 70 Answers
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Posted on Jul 28, 2008
SOURCE: panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Posted on Sep 27, 2008
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
  • 176 Answers
SOURCE: Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Posted on Jan 22, 2010
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Aug 03, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Record tv with Panasonic DMR-E75V DVD Player / VCR
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
Jun 15, 2008 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
