Question about Hitachi P50H401 50 in. Plasma HDTV
What type of screws are used to secure the TV to the base
    Problem Solver:
  • 19 Answers
Although the base is plastic the holes where screws go are normally always metal fixed thread like grub screws, most tv use similar fixtures to fit tv to base , I would pop along to a electrical store and try and look at the screws used to fix the tv that are on display and compate a few, then try buying a set of 1/4 inch pan head metal thread screws from DIY store
Posted on Dec 07, 2012
  • Mike Dec 07, 2012
How do you install the feet on the Model 32K3110W TV
To install the base, put the TV down on a clean flat surface covered with something soft to avoid scratching the TV's screen. Put the two base pieces into the slots on the bottom of the TV; they will only fit one way. Next secure the base with two screws for each leg. With the 32" TV, you need ST4x12 screws. This is shown in the Quick Setup Guide and is available from the Hisense product support page: http://hisense.com.au/single_support/32in-led-series-3-32k3110w/#product-manuals . See page 1 for the parts list and page 2 for a sketch of putting on the base.
I hope this helps.
Apr 29, 2016 | Televison & Video
I have just bought 32 inch sharp flat tv. I want to connect the base to the tv but the package did not come with screws or bolts. What type and size of screws or bolts do i need? Where can i buy the screws...
What is the model of this 32" Sharp TV? Some stand is snapped in type.
If they use screw, they will be Metric screws, either M4, or M5 from HD, or LOWE'S, or ACE hardware, about 35 cents each.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Aug 26, 2011 | Sharp LC46LE810UN 46 in. LCD TV
How to take a honeywell radiator off the wall
Turn off the circuit breaker to the AC and heating unit. The circuit breaker is inside the home electrical box. The door of your electrical box has a guide indicating which circuit breaker controls the cooling and heating system.Pull the cover off the Honeywell manual thermostat. If necessary, use a flat-head screwdriver to pry the cover away from the base of the thermostat. Locate the two small screws securing the sub-base to the base of the thermostat. The sub-base is the portion of the thermostat that has the indicator dial or indicator lever. Remove the screws with a Phillips-head screwdriver, and pull the sub-base away from the thermostat.Remove the screws securing the base of the thermostat to the wall with the Phillips-head screwdriver. Pull the thermostat base away from the wall so you can access the wires.Loosen the terminal screws securing the wires to the back of the thermostat with the flat-head screwdriver. Wrap the wires around a pencil or a large screw. This will prevent the wires from accidentally falling inside the wall cavity.
Jun 12, 2011 | Honeywell Heating & Cooling
TV tilts forward on base about 15 degrees, TV will pivot left or right but won't remain perpendicular or upright.
The only things I could think of causing this would be either the hardware not tightened up properly or defective base (stand.) Make sure all the screws are tightened securely in the bottom of the base and in the back of the tv where the base attaches. Someone may have used the wrong screw holes to attach the base but there really should only be 4 holes to use to screw the base to the tv. This may need returend to the retailer for an exchance of the base.
  1. Oh, the last thing to check is that someone did not put the base on in reverse. Most have a small alightment tab that makes sure the front of the base goes to the front of the tv and if it is put on backwards the tv would tilt forward a few degrees.
Mar 09, 2011 | LG 42LC2D 42 in. LCD HDTV
I want to remove the base from my Sylvania lcd 37" tv
Look towards the middle back of the tv there should be four screws that you can remove to remove the base. Follow up from the base they will be evenly dispersed in th emiddle of th etv and they will all be the same screw type after removing them slide out the base.
Thanks,
Michael
Feb 06, 2011 | Sylvania LD370SS8 37 in. LCD Television
Sony Bravia KDL-V40XBR1. Lost the main screw to the base. The one that secures to the bottom of the base into the tv. What size is it so I can replace it!
Required screws part number is as follows:
258064001.... SCREW +BVTP2 4X16
Available in PartStore.com for $5 each
Hope these info will help you.
Thanks.
Nov 26, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We can't figure out how to remove the base on our new 50" Sanyo Plasma TV so we can hang it on the wall...HELP!
look at the rear of the tv there are four phillips head screws holding the base on unscrew them and lift the base off
Apr 15, 2009 | Sanyo DP50747 50 in. Plasma TV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Hitachi P50H401 50 in. Plasma HDTV Logo
480 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
