Question about Sewing Machines
Bernina overlocker 1100da troubleshooting manual
Was locking and than it just stuck the needle is not budging a bit
bargainbox
  • 1388 Answers
SOURCE: Help, Janome Ezy Lock 304D Overlocker!
Although the tension units on your machine are of a different configuration, always thread from the right spool first and then each one to the left.........ONLY in that sequence !
now take a look at this sewusa site for a better view of the actual routine through the thread guides.........as I say, the tension units are different, but the sequence is the same, just use the image from above to see which one is next........this chart, just as the one on the fold down cover of your machine need to be followed one thread at a time from R to L
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 08, 2008
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
SOURCE: I need a manual for the Bernina Bernette 203
you can download the manual for 234. Its your machine just a 4 thread. Use this link:
http://www.berninausa.com/news_detail-n486-i2240-sUS.html
Posted on Jul 21, 2009
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
  • 233 Answers
SOURCE: is it possible to download
Go to http://safemanuals.com/user-guide-instructions-owner-manual/BERNINA/700D-_E. After rating the machine, you can download the manual, virus free, for free.
Bernina manuals aren't easy to find online! I'm so glad I found this one for you!
Posted on Jun 02, 2011
Hi. I have a new overlocker. Fabric got jammed ,got it out but machine now jams at half turn . Could some fabric still be under feed dogs ? How to get it out ?
Hello Jenny hornsey
This may sound traumatic, but there is no easy way to pin point where the tie-up is located. So proceed as follows.
Cut all the threads as they come off the antennas.
Open the front cover and pull-out all the threads by pulling them straight toward the back. If they do not come easily, try moving the hand wheel back and forth by a 1/4 revolution .. this is like a rocking motion. If still not budging, start cutting back the threads and removing them in sections until all the threads are cleared. If this step is still challenging; check that there is no residual fabric or threads still wrapped around the loopers or other part/s of the serger. If so cut them out bit by bit until everything below is cleared.
Great. Now check for threads wrapped and/or jammed anywhere above.
Since the overlocker jammed, it is possible that the needles were bent. This will continue to cause issues in stitch formation. So just to make sure; change the needle/s. Make sure that the correct needle type is being used. Every overlocker is engineered to be used with a specific needle type. The needle type will be specified in the manual and will also appear on the needle package. If the needle types are not the same, do not use those needles.
Re-thread the overlocker and stitch test on a piece of fabric before pressing down on the foot control.
This should get the overlocker back on track and you back to overlocking.
Please let me know how this works out for you.
Happy overlocking
Sewingirl/
Mar 18, 2017 | Sewing Machines
How to fit needle in nina 787 overlocker
Perhaps it is not the correct needle for the machine. There are some needles that are a tad bit longer than the standard sewing needle (my non-Bernina coverstitch takes a longer needle). Although not familiar with the 787, most Bernina sergers use the same needle as a Bernina sewing machine.
When installing the needle, be sure to push it all the way up (as far as it will go) when tightening the skrew.
If it continues to break the needle, the machine could be out of time and need service.
May 31, 2016 | Sewing Machines
Need a manual for Bernina 1100da Overlocker
The Bernina 1150 is similar enough that you can probably use it for your model. Here's a download:
BERNINA Support Machine and Accessories Finders and Software Support...
Aug 09, 2013 | Sewing Machines
I need a manual for Bernina 1100DA serger
Here's a manual for the 1150. It's probably close enough to your model.
http://www.bernina.com/en-US/Support-US/Machines/BERNINA-Overlocker/BERNINA-1150MDA
Apr 06, 2012 | Sewing Machines
Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
