Question about DeVilbiss Bostitch Compressor Fan Ab-9038159 Cap1545pt-ol Cap2040st-ol Cap2045st-ol
STANLEY BOSTITCH TANK COMPRESSOR CAP2045ST-OL manual
Anyone know HOW I can obtain a Manual for this product ?
How can I get a parts repair manual/list for a stanley fatmax 3.8 cfm compressor
try searching for stanley fatmax compressor . I think bostitch owns it
Nov 03, 2014 | Measuring Tools & Sensors
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
Jim:
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Bostitch AB-9048025 What's it made of?
Bostitch calls the AB-9048025 a non-return valve, most compressor companies call then tank check valves. All the check valves I've worked with are brass with a spring loaded, plastic valve to hold the air in the tank when the pump shuts off. Many are interchangeable with a little line re-routing. You can find the AB-9048025 on sites like www.ereplacementparts.com. Also, on that site, you can put "tank check valve" in the parts search box and get a list of valves available and most have pictures of them so you can see what you'd be working with.
Nov 06, 2012 | Stanley Bostitch AB-9048025 Check Valve
Large red pressure adjustment knob on my compressor is broken and will not screw on, compressor will not hold pressure
You may have to replace the regulator as many of them do not sell just the knob. If you go to this link and put your model number in the search box you will be able to see what is available for it. By the way, Stanley (Bostitch) merged with DeWalt so all the breakdowns for Bostitch can be found on the same site now.
DeWalt/Bostitch parts and owners manuals.
Aug 19, 2012 | Stanley Air Tools & Compressors
How do l get a repair manual for bostitch comp cwc200st?
Bostitch was purchased by Dewalt and moved their service and parts information to the following location:
http://servicenet.bostitch.com/ . If you have a Dewalt service center in your area, they should have or can obtain the specific information that you need. Good luck
Oct 20, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
I have this compressor and when I pull the switch to turn it on nothing happens. It is only about 5 months old. Is there a reset switch or somthing?
Hi and welcome to FixYa, I am Kelly
The parts schematic can be found on this page:
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=CAP2000P-OF&serialNum=
Pop-ups have to be enabled to see the pdf file schematic that will come up with this address:
http://www.bostitch.com/catalog_images/web_pdf/IP1275-1REVA.pdf
I tink your pressure switch has failed that is item 21 of the above link. The SHOULD be a warranty repair. Item 21 : AB-9415626 0021 PRESSURE SWITCH $21.60
It is possible that the motor itself has failed but on a unit 5 months old the pressure switch is the most likely suspect.
The warrnaty Service has an "At your expense shipping" statement.
To obtain warranty service, return the product at your expense together with proof of purchase to a
Bostitch Regional or authorized warranty repair center. You may call us at 1-800-556-6696 for the
location of authorized warranty service centers in your area.
Bostitch, Inc., warrants to the original retail purchaser that this product is free from defects in
material and workmanship, and agrees to repair or replace, at Bostitch's option, any defective
product within 1 year from the date of purchase.
Maybe you live in area where you could do a carry in service.
For sure I would call them.
Thanks for choosing FixYa,
Kelly
Feb 23, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
Looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Jan 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
DeVilbiss Bostitch Compressor Fan Ab-9038159 Cap1545pt-ol Cap2040st-ol Cap2045st-ol Logo
93 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
