Question about MPC Computers Micron Transport LT Series
Micron Transport TREK II, Intel Pentium II (Help)
I got a Micron TransPort TREK II off ebay, It has a Battery, CD-ROM Drive and Floppy Drive. It is missing the 56K Modem, Hard Drive and AC Adapter. I own a IBM ThinkPad T40 and used its AC Adapter on it and with luck it fits on the TREK II, The Battery light flashes when I plug it in and then goes out. I'm trying to find out what Hard Drive Adapter I need for it because it don't have the EIDE Port, and I can't find the RAM socket on here. It's not powering on.
  • 1 more comment
  • Patrick Bridge
    Patrick Bridge Jan 12, 2009
    I found a AC Adapter thats works on it so the Battery is charging right now, the light is on, Still need to find its Hard Drive Adapter and RAM Socket location.
  • Patrick Bridge
    Patrick Bridge Jan 13, 2009
    The light from the AC Adapter is still on and went to press the power button and nothing happend. Could it be the AC Adapter? It says on the bottom of the Laptop 19Volt and the AC Adapter says 15Volt, could that be why the laptop doesn't want to power? Its the only AC Adapter I have the I can find that will fit in this. And my ThinkPad T40 AC Adapter when pluged in, the lights don't come on at all. and the AC Adapter is a 16Volt.
  • Patrick Bridge
    I found a manual online and found where the RAM is located, Its under the keyboard witch I removed and there is 2 sticks of RAM in it, But can't tell the number of size they are, like 64MB or 256MB.
5 Suggested Answers
  • 18 Answers
SOURCE: My computer goes offf when I load the computer. Micron TransPort GX and ZX
wait does that hard drive an external drive?
try to put/connect the hard drive 1st b4 you turn on you computer...
make sure that your hard drive is not set as primary master...
see the labels or details on the hard drive....
>because this cause confusion in the enlisted drivers... plus it also may have the same letter drive...<
so after connecting the hard drive... turn on your computer...
if still the same problem occur try to reboot your computer and log in into safe mode (windows xp) by press F7 right b4 it loads the window xp logo...
do not chose to restore your computer...(pop up window that request to restore or not) just load it...
that should do the trick
(note if the windows safe mode is requesting to check that hard please drive do so...)
please vote ; >
or email me jealcon_23@yahoo.com
Posted on Jul 08, 2009
  • 1121 Answers
SOURCE: The adapter for my micron pc transport gx3 is not
Power cord is available in electronics stores, go there you find-it
Posted on Nov 29, 2009
marked
  • 6487 Answers
SOURCE: what is the max size of hard drive and memory i
You can go up to 80 gig of hard drive for this one.....
Posted on Dec 13, 2009
durtopian
  • 408 Answers
SOURCE: micron transport lt driver for
G to www.mpcdrivers.com for all your drivers
Posted on Aug 15, 2010
Where to find a Transport T2200
Try eBay they have some less than $20. Just make sure it is new and that it includes both the AC Adapter & the Power Cord.
http://www.ebay.com/itm/6FD4BF-AC-Adapter-65W-Micron-MPC-Transport-NBK001565-00-T2200-ZX-/190555003879?pt=Laptop_Adapters_Chargers&hash=item2c5df69be7
Mar 19, 2012 | Computers & Internet
MPC Micron T2300 Hard Drive Cable.Where can you buy one.
You can get the item needed for your device at ebay.com, it is a convenient place to buy computer and laptop accessories.
Take care.
Nov 19, 2010 | MPC Computers TransPort T2300 Notebook
Need Mcrosoft XP disc to clear Micron PC TransPort GX3
google.com - make sure you keep it short, some sites will offer the cd cheap if you can wing it. Other wise if this doesn't help, create one yourself. Another good tip: Microsoft.com has that cd too, wouldnt you know. ;)
Feb 06, 2010 | MPC Computers TransPort GX3 Notebook
Hard Drives
You should be able to see the drive under either my computer in windows explorer.
Jun 14, 2008 | Gateway E-2000 Deluxe PC Desktop
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Micron Transport Trek 2 mod#NBKU370, ser# 1392070-00311
I think it means that either the hard drive has failed, or that it is not detecting it. try downloading a program called Bart PE Run this disk in the CD Drive on startup. then find the option called command prompt. then type in the following as follows:
chkdsk C:/r
after this finishes, shutdown, remove the disc, and see if the laptop will boot now.
Feb 05, 2008 | Computers & Internet
Need to Upgrade Hard Drive & Memory for Sharp PC-UM10M
SHARP PC-UM10 SPECIFICATIONS
CPU Ultra Low Voltage Mobile Intel® Pentium® III processor 600 MHz-M Memory 128 MB SDRAM, not expandable (model PC-UM10) 256 MB SDRAM (model PC-UM10M) Video ATI Rage Mobility M (including 4 MB video RAM) Display 12.1" XGA AGLR TFT LCD (1024 x 768) Hard Drive 20 GB Pointing Device Glide pad (touch-sensitive control pad with 2 buttons) PCMCIA 2.1 Card Slots Type II x 1, CardBus port supported Audio System Monaural microphone and monaural speaker, sound system compliant with AC 97 I/O Ports USB, LAN, modem, headphone, microphone, DC in, expansion port for port bar Modem 56Kbps (V.90) LAN 100Base-TX/10Base-T AC Adapter 100-240V, 50-60 Hz Battery Rechargeable lithium ion battery Battery Life Standard battery - approx. 3 hours. Optional extended life battery (CE-BL18) - approx. 9 hours. Battery life is based on ZD Battery Mark 4.01. Battery life may vary based on actual usage. Dimensions 11.1" x 9.1" x 0.65" (min)/0.77" (max), 282mm x 232mm x 16.6mm (min)/19.6mm (max) Weight 2.89 lbs., 1.31 Kg Operating System Microsoft® Windows® 2000 Operating Environment Temperature: 50°F to 95°F (10°C to 35°C) Humidity: 20% to 80% (non-condensation) Power Consumption Max. 40W Available Options Extended Life Battery CE-BL18 Optional longer life battery 6X CD-ROM Drive CE-CD05 External USB CD-ROM Floppy Drive CE-FD04 External USB Floppy Drive Port Bar CE-PB01 Provides additional I/O ports
Design and specifications are subject to change without prior notice. Some options may not be available in some regions.
[HOME] [NOTEBOOKS]
Oct 22, 2007 | Sharp PC UM10M Notebook
Computers & Internet Logo
270 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
