Question about Echo Garden
Echo chainsaw dies when tilted on its side - Echo Garden
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Posted on Oct 12, 2009
dontbother10
  • 2220 Answers
SOURCE: Wanted manual for echo 320 vl chainsaw
Ordinarily I would send you here for a download but your saw is not listed.
EchoUSA
http://www.echo-usa.com/faqs.asp
Click “2. MANUALS, Catalogs, MSDS and Installation Instructions”
Then “Operator’s Manuals/ Parts Catalogs/ Safety Manuals/ ~more~”
Please try here:
http://www.echo-usa.com/faqs.asp?FAQPage=Quest
For all that follow you please include a request they add literature your saw to to the list. HTH
Lou
Posted on Nov 29, 2009
Testimonial: "Excellent service, sincere thanks . Paul Turnbull ( France ) "
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
How does the oiler work on a echo cs440 chainsaw
hello, depends on the model you have, mine has a gear drive,and others are gravity flow,there is a inside tube with a filter that drains to the out side for oil,hope this helps.
Feb 22, 2012 | Echo Garden
Echo 750 saw runs for two minutes then dies icheck the plug it has gas on it and plug still sparrks put back in starts runs for two minutes or less and dies again?
Could be a fuel tank breather issue, when it starts to die slacken off the fuel cap, to see if it picks up again, if it does you need to replace the breather.
Feb 16, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
Nov 26, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
77 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
