Question about Dell Dimension 2400 PC Desktop
If I don't have disks to install os on a dell deminsion 2400 is there anyway to do it without the disks
My computer just keep rebooting and won't let me go to safe mode. I can get to the screen to do so, just won't let me.
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Posted on Dec 08, 2012
  • 18 Answers
SOURCE: trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Posted on Dec 06, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Need to Rewrite/Reboot Dell Desktop 2400 series and cant
Press Delete at start up, change the first boot device to your cd drive, then F10 to save settings and restart. Put your Windows XP disc in the drive and press any key when prompted to boot from the cd.
Posted on Jan 01, 2009
Astrophel
  • 116 Answers
SOURCE: windows will only start in safe made after sp2 or 3 install
you likely have some software issue that prevents all the new services from loading, most likely it is related to the antivirus/security software.
try disabling all the non-MS Services and all statup items in MSConfig, if it starts normally with all this disabled, reenable them a few at a time until you find the offending software
START
Run
type "MSCONFIG" withou the quotes
click the services Tab
check "Hide all microsoft services"
click disable all
click Satrtup Tab
Disable all
OK
allow to restart
during startup you will see a screen that says you have made the changes, this is normal (when you are all done, check the don't show again)
once you have found what causes the issue, Google the startup item and uninstall the related software.
Hope this helps
Posted on Jan 05, 2009
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
Is there anyone who can help me with my dell 2400 deminsion desk top pc
You may need to reformat the hard drive to have enough space for the new operating system. Did you remove the old OS first?
Jun 11, 2014 | Dell Dimension Computers & Internet
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Can i make a bootile usb for dell dimision 2400
If the BIOS setting for the Boot up device order does not have the USB as a boot up device then it is not possible to boot up your computer with an USB device.
For a Drive 0 seek problem -
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 19, 2012 | Dell Dimension 2400 PC Desktop
My Dell Dimension 2400 has stopped working - how do i restore the factory settings ?
It appears your model Dell 2400 should have been supplied with the CD's for reinstalling Windows XP, CD will be green or blue in color and the drivers and applications that came with the computer.
If so, back up your files first to an external drive and then put the CD in the CD drive and reboot the computer. It should come up to reinstall XP.
If good to go, you will be prompted to install the second Cd as well as online XP updates.
Software that was installed after you bought the computer also wouyld have to be reinstall as well as restoring your backed up file.
Rememberm all data is lost when you reinstall your operating system, unless these is a choice on install that may ask for destructive, or non-destrutive (keeps files).
I am attaching a link to Dell for your to copy and paste into your web browser for the support page for drivers and user guide in the event you need to reveiw the process.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Sep 06, 2011 | Dell Dimension 2400 PC Desktop
How to install a fresh OS in my dell optiplex110?
You would need the restore discs to preform this.
May 03, 2011 | Computers & Internet
How do i format it to how it was when i got it
If you still have the disk for your OS then the process is fairly simple. Insert the disc and reboot the computer. While the computer is booting hold down ESC or possibly F2, F8, or F12. A boot menu should open up before your operating system begins to load and you should pick to boot from CD Drive. When the setup loads, go through the menus until you get to the section of where to install the OS. Delete all the partitions on your computer and then reinstall the OS on the new one. This will delete everything on your laptop and just have a clean copy of your OS.
If you don't have the original CD you can download and burn this onto a CD and boot it from CD. This will securely wipe your hard drive.
Apr 25, 2011 | Acer Aspire One PC Notebook
I don't have a dell reboot disk or a blank disk to download onto is there anyway to reboot my dell laptop without this
There are actually 2 ways. The first is after you have turn your PC on and while it's trying to reboot press the F8 repeatedly and select Safe Mode. So it means that you will be using Safe Mode to boot up. The other way is to use the OS disc(e.g Windows) that you have.
Sep 13, 2010 | Computers & Internet
I have a dell dimension 2400 and want to reload operating system , dump every thing and start over. I re load the windows OS disk but didn't dump all the old files and programs .I have several disks that...
Hi:
Basically, you need to do four steps:
1) Run the Windows OS installation
2) Install all drivers off of the driver CD
3)Install programs and software that came with the computer, or ones that you added .
4) Connect to the internet, and validate your copy of windows, and run Windows Update again and again, until there are no more updates to download.
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Trying to do a factory restall of Dell demnension 2400
typically you don't need to press ctrl at all -- usually f11 does the trick -- or going into accessories and system tools and looking for factory restore or something similar, the program has different names depending on the manufacturer. System Restore will only bring it back to a previous date...
Jun 26, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
