Question about Sharp LC-32SH12U TV
Sharp LC-32SH12U LCD Screen Malfunction
I have a Sharp LC-32SH12U LCD tv and the screen has been malfunctioning recently. My sound works fine, but the screen takes up to an hour to work. When first turned on it is frozen and gradually begins to show still images of the program on that it should be showing. From what I have read this is most likely the t-con board. I have since taken apart the TV and noticed that the inverter board appeared to have a lot of flux or maybe a little heat damage. What symptoms would I see from each component going bad and how can I definitively determine which one I should replace?
4 Suggested Answers
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
budmrtn
  • 11361 Answers
SOURCE: Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
Posted on Nov 19, 2009
Testimonial: "Thanks for the response. I found a PWB board, a Power board and an AV board. Would one of these fix the problem?"
  • 74 Answers
SOURCE: I have a Sharp LC-32D44E LCD TV. Purchased Oct
If the red light stays on and the tv does not react to any input from buttons or remote... the problem is one 7 pins integrated circuit on the upper side of the power board .the ic is situated on the right side of the power socket .It costs about 2$ and can be replaced by someone with mimimal electronics skills and a 30w solder iron .
Posted on Apr 20, 2010
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
Jan 29, 2013 | Sharp LC-32SH12U TV
32sh12u screen lines
you possibly have bulged capacitors or loose connectors..
or also you possibly have faulty t-con board.
Dec 05, 2012 | Sharp LC-32SH12U TV
Sharp model LC-32SH12U - 2 hdmi ports - whenever anything is plugged into them - ps3, apple (MBP, via cable, blu-ray player) they just show a green screen. We checked other hdtv's and it is just this tv. ...
I don't have a solution but starting 2 weeks ago I have the exact same problem. Test different devices and cables and it points back to the TV. Anybody have a solution?
Feb 13, 2011 | Sharp LC-32SH12U TV
MY SHARP LCD TV HAS PERFECT SOUND BUT WHEN WE TURN IT ON THERES NO PICTURE JUST RANDOM RED LINES.IF WE TURN IT ON AND OFF THEN THE PICTURE WILL EVENTUALLY RESUME
I don't have a solution, but the same thing happened to ours. To sidestep the problem, I just left it on 24/7. Eventually (three days ago) it just stopped working completely.
Dec 25, 2010 | Sharp LC-32SH12U TV
I was playing Playstation on it and it lost power.
Unplug the tv about an hour,replug it back in should reset it self and work.Not, the power supply board it dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 12, 2010 | Sharp LC-32SH12U TV
Ihave a sharp lc32sh12u tv and when I turn it on
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Should solved this problems.
Apr 24, 2010 | Sharp LC-32SH12U TV
Nov 18, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
Audio O/K no picture . Model Sharp LC-32SH12U. Thanks "Larry"
Check for a backlight failure by holding a flashlight on the screen at about a 30-degree angle, a couple of inches from the screen. Look at the area around the flashlight beam. If you see video, either your backlight fluorescent tubes are burned out or the inverter has gone bad. If you need tubes, search for "CCFL replacement" (CCFL = cold cathode fluorescent lamp").
Aug 10, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
I ACCIDENTLY SEEMED TO ENTER A CODE TO BLOCK CHANNELS IN MY TV SET AND NOW DO NOT REMEMBER WHAT THE CODE IS? IS THERE ANYWAY I CAN RESET?
To reset/clear the password for the LC-32SH12U TV, PRESS and hold both VOL-- on the TV and press 0 on the remote control simultaneously for a few seconds until (LOCKS) menu appears on the screen.
Now the old password was cleared. You can set the new password.
May 28, 2009 | Sharp LC-32SH12U TV
Sharp LC-32SH12U TV Logo
107 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
