Question about Kitchen Ranges
E1 F5 error message on my kenmore range
Occurred after cleaning please help need to bake cookies
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
This is a door lock error
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct. What is the model number?
Posted on Dec 08, 2012
  • 172 Answers
SOURCE: f5 code on a kenmore range
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
fridgetech
  • 473 Answers
SOURCE: Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Posted on Oct 21, 2007
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Posted on Aug 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: We used the self cleaning option on our Kenmore
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
I self-clean my oven last night. It still says it is looked and I see E1-F5. I can not open it. I even unplugged it but it went right back to the same message.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^$R
Aug 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
We used the self cleaning option on our Kenmore Gas Range (model number 665.72004101 or 665.75004101) and now the oven door remains locked and the error message on the screen is e1 - f5. How do we unlock...
Dec 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Trying to self clean my kenmore electric oven get error msg e1 f5
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
E1 F5 came out and door is locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^RF
Jul 20, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
I tried to set my self-cleaning on my Electric Kenmore range model # 66592012100 and I get the error message E1 F5 I can't set my oven to self-clean just my luck
May 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
I have a Kenmore self cleaning electric range # 95014. When I try to start the cleaning feature it seems as if it is going to start then it beeps and E1 F5 comes on. What do I need to do.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.DGF$^%&*
Feb 25, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Self Cleaning won't work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%TY
Feb 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
E1 F5 error message when try to activate the self clean
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
