Question about Sanyo Audio Players & Recorders
Dmc 4010 will not start
Will not boot up
810-4010-0 replacement parts
Search Results for 810 4010 0
Click on above link. Then click on parts and order.
Semper Fi,
Z
Dec 27, 2013 | Brinkmann 810-4010-0 Grill
Why cant i boot this machine?
Some newer machine will not boot if an external USB memory stick is connected to it.
Remove all USB device(s),CD or DVD and try again.
Aug 19, 2011 | Acer TravelMate 4010 Notebook
I have a digimax 4010. Do I get a 2mg sd card? What is the diference between a sd card and a sdhc
SDHC is an extension of the SD standard that extends the capacity from 2GB to 32GB. It's backward compatible in that devices designed for SDHC cards will also work with SD cards. It does not go the other way---that is, SDHC cards will not work in devices designed for SD cards.
I presume you mean a 2GB card, since a 2MB card might hold one picture.
The Digimax 4010 works with SD cards, not SDHC cards. You may use an SD card. Just make sure it is an SD card, 2GB and smaller. SDHC cards start at 4GB and go up to 32GB but, as stated earlier, will not work in the 4010.
May 25, 2011 | Samsung Digimax 4010 Digital Camera
My friend's TravelMate 4010 had a serious virus which I was eventually able to get rid of by reinstalling the operating system through Alt-F10. However, the dvd/cd-rw isn't recognized anymore. I tried to...
reboot it under f2 when it starts up put disc in push f2 or f12 depending on your boot settings are set on. run under d. drive the best one for your travel mate is windows vista.
Mar 14, 2011 | Acer TravelMate 4010 Notebook
I have Acer travelmate 4010 laptop >>>
Download a copy of Hiren's Boot CD from here and burn it on a disc: http://www.hirensbootcd.org/download/
Upon start up you will get a menu similar to this one:
Under advanced boot options boot from the one that suits your operatin system (XP or Vista or Windows 7). If it loads it means the bootmgr is corrupt, you can try to repair it with the Windows installation disc, instead of Install choose Repair.
Now, regarding the BIOS password, you will have to select Dos Boot CD and go to BIOS/CMOS menu and run Kill CMOS to wipe the BIOS completely or there are some utilities there that can reset just password. There re some other options too for reseting the password that you can read about here: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
Jan 26, 2011 | Acer TravelMate 4010 Notebook
Need to reset the bios on Travelmate 4010, as it has BIOS password and HDD password locked
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 30, 2010 | Acer TravelMate 4010 Notebook
Acer travelmate 4010 model zl1 ; pxe-e61: media test failure , check cable; system won't boot; operating system not found
clean filesystem with a scan disc if it isnt a mother board failure reinstall OS from external drive
Sep 06, 2010 | Acer TravelMate 4010 Notebook
Maestro 4010 screen freezes up when first button pressed. Switch off and restarted but does the same each time.. Where do I get the software to update ?
there is no updates for the magellan 4010 at this time. if you havent tried the reset (little pinhole on the left side) i suggest you try that 1st.
power on your 4010 and after it boots up, use a paper clip to depress the reset switch and let it reboot. that may or may not fix it, because you could have a bad digitizer (the touch part of the lcd)
let me know how you make out.
bill
Dec 15, 2009 | Magellan Maestro 4040 GPS Receiver
Boot safe mode
to boot safe mode,
1. tap the f8 button while your computer boots...before your windows starts load and just after you press the power button.
2. a screen will appear it will give you the option to boot in safe mode, select it
Dec 28, 2008 | Toshiba Portege 4010 Notebook
I forgot my password
Restart your computer, pressing F8 while it boots up. You will see a list of boot options, select Start in Safe Mode. Log in as Administrator. You should then be able to change your user's password in Control Panel -> Users.
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
