Question about Microwave Ovens
Samsung C103FL microwave pcb not working
Display pannel not working
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Maytag MMV6178aaq microwave display not working.
Well, assuming your connections are good on the board, and you;re getting about 3VAC on the filament leads (outermost two pins), I'd say you would need a new board assembly.
(The VFD tube is not available separately).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 10, 2009
Dacor DM02420S Micrwave Display Screen - Can't see anything
can you see any thing like a circuit in that pannel.check for the soldering joints in that pannel.
Oct 12, 2008 | Dacor DCM24 Convection/Microwave Oven
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
Microwave model 44546.digital pannel- what does the icon which looks like wifi means?
Check the manual for more details: http://kitchen.manualsonline.com/manuals/mfg/electrolux/b_81405.html?p=62
Jun 16, 2014 | Morphy Richards Microwave Front Switch...
Samsung c103fl microwave
use the VOM and proceed according. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 18, 2013 | Microwave Ovens
Microwave display not working
DISPLAY PANNEL NOT WORKING NO START BUTTON
Feb 24, 2013 | Whirlpool Microwave Ovens
I have a samsung microwave oven with model no. C1113 purchased on 19th April 2006. Last month it stopped working when I registered my complaint with the customer care after nearly 15 days the service...
I need to know what is wrong with the appliance.
Does the display work?
Does the machine appear to work but with no heating?
Is the machine dead?
Feb 02, 2011 | Microwave Ovens
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
May 13, 2009 | Sharp R-303CW Convection / Microwave Oven
Microwave was working fine. Suddenly stopped.
First thing to try is to check the power point.
If there is power there, but still no activity when you turn it on, no display no lights, it will need to be taken in for service. Sorry for the bad news but hopefully it's just the circuit breaker for your power point.
Apr 26, 2009 | General Electric Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
