Question about Hotpoint Washing Machines
Hotpoint aquarius wmf560 flashing f10
Stops near the end of cycle
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
Posted on Dec 07, 2012
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
  • 1294 Answers
SOURCE: Hi my hotpoint aquarius keeps stopping on evry
I hope the below could be helpful, if so you must rate me nice. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too.
Posted on Jun 05, 2009
  • 53 Answers
SOURCE: Hotpoint BWD129. Door lock flashing rapidly,
sounds like your pump/filter is blocked. clean everything out.POWER OFF.
Posted on Oct 16, 2009
My hotpoint aquarius wmf560 won't turn on no power since I moved it from my old house yesterday any ideas ???
sounds like a blown fuse or broken wire
cut back the wire by 6 inch and rewire plug replace with 13 amp good fuse
Dec 17, 2015 | Hotpoint Washing Machines
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wt960
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
