Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Will not stay running
Hi i have a bissell healthy home vacum cleaner. every thing runs fine as long as i hold down on the button as soon as i let off of the button it stops. i cant find any info. on this. can you help. thanks tom model 5770-h 08050c
  • 1 more comment
  • fruitjart Jan 14, 2009
    where is my answer
  • Anonymous Apr 26, 2009
    I paid a lot for this thing...I have the same problem...can't find any help!!
  • Nathan
    Nathan May 11, 2010
    is the switch a pedal?
  • 281 Answers
You have a bad switch.if you have any spray contact cleaner you can spray it in the switch and work the switch a few times and see if it works if not you need to get a new switch.you can get the switch at any vacuum repair shop.if you would like call all-type vacuum and janitorial supply and ask for lisa.she can help you.tell her pete advised you to call.contact cleaner you can get at radio shack.i hope i have been of some help to you.please leave feedback
Posted on May 04, 2009
  • Geoffrey Sutcliffe
    Geoffrey Sutcliffe Jan 26, 2012
    The screw holding the top of the handle to the middle of the vacuum is loose. If there is a non flush seam right below the brush attachment storage on the front, push from behind to make it flush again and tighten the screw holding the upper piece to the middle.
  • markdebbond Feb 22, 2012
    Same problem with a 6-month old vacuum. Could only use it if I continuously held the red power switch on. So I took Geoffrey's advice. I removed the screw on the back side that holds the upper portion of the handle, removed that portion of the handle, and reinstalled, making sure the screw was tight. Everything is working like normal now! Thank you!
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The vacuum will only run as long as I am pushing and holding the "on button".
switch is bad its still under warranty bissell will replace the whole handle
Dec 04, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell healthy home won't stay on unless i hold the start button
We had the same problem. Open the handle by undoing the screws and then pull one side off. Depress the button a few times and see if it catches. It worked for us and now it is just like it should be again. Good luck!
Oct 31, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Mar 29, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
334 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
