Question about Dishwashers
Bosch Dishwasher has error code e24, I checked the line, replaced with new pump, new control unit and call repair man no luck. It works on and off. I get it run then next cyle nothing. Heelp!
howapp
SOURCE: My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
Posted on May 21, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
SOURCE: bosch dishwasher lfestyle automatic runs for 1 min
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Posted on Mar 31, 2010
SOURCE: bosch dishwasher has e24 error code and does not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn’t work and your machine is still under warranty, call Bosch. Bosch won’t tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don’t look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty. It doesn’t take a rocket scientist to figure out how to clean out the airgap, which isn’t a part of the dishwasher, but rather part of your plumbing connected to the dishwasher. I suspected this to begin with, but because you told me I needed a service call, I had to assume it was beyond basic owner maintenance. Great way for you to flush money down the toilet and look bad doing so.
Posted on Apr 30, 2010
  • 608 Answers
SOURCE: I have a bosch dishwasher
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Posted on Dec 09, 2010
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
I have a Bosch dishwasher that had error code E24. DW would work if door was opened about 1 minute into washing. New drain pump. No fix. New error code of E21. New control unit, still same problem.
E21 is a circ pump blockage issue. Check that all hoses are clear, unit drains completely. Depending on the age, a new circulating pump may be needed or new motor capacitor.
Jun 22, 2016 | Bosch Dishwashers
Error -24 message want let me download it
Hello you haven't said the make of the dishwasher.
  • The E24 error is one that I am used to with Siemens and Bosch models. E24 indicates one of two things.
  • Frontally there may be a water evacuation problem. Check the drain outlet under the sink where the hose connection is
  • check inside the "well" of the dishwasher. You can remove the plastic pump cover to check for foreign items stuck in there.
  • If this is all clear then the E24 will be associated with the wash pump being stiff. Possibly due to a worn bearing.
  • You will need professional service to fix this.
Good luck.
Nov 21, 2014 | Dishwashers
What does e24 mean
The error code E24 on Bosch dishwashers is a drain error code although it can be triggered by the circulation pump or main control issue. The first thing to check is your drain system, make sure the filters are not plugged and the check valve is in place. Your check valve is located in the bottom of your tub on the side wall, generally white in color. If those two things are looking good check your drain hose is it kinked or clogged? (Did you just replace your garbage disposal, if you answered yes, remove the plastic plug that comes on the new disposal.)
The next thing to check is your drain pump, when you press cancel can you hear a humming noise? If not you will need to check for power to the drain pump, there should be 120v. If all the items in your drain system test OK and you are still getting the code the next step will require you to remove the dishwasher from the cabinet.
After the dishwasher has been removed from the cabinet you will need to get to the main control on the lower right side. Make sure the breaker is turned off to the dishwasher at this time. Remove the connector with the three grey and three black wires. Your looking for 89 Ohms on the grey wires going to the drain pump, and 14 Ohms across the black wires going to the circulation pump. If those both check out you will need to replaced the main control.
( Just a quick update if your wash motor is not working properly this will also make the code come up. If the brushes in the motor get old this will cause the motor to drag and that's what triggers the error code.) Hope this helps!!!
Jun 02, 2014 | Bosch 24 in. SHE66C05UC Stainless Steel...
Error message e21. Bosch dishwasher
My mom had the same issue with her fancy bosch dishwasher! It ended up being a hose, if I remember correctly. Her problem also took two repair trips, I know for sure it was not a new motor issue. I would have someone check the hoses and the electrical panel.
May 28, 2013 | Bosch SMS68M02AU Dishwasher
E24 error code and noisy
Check pump, follow info in user manual to check, if you don't have manual use the link, to download a copy, make sure that the pump cover is clipped back in place before testing.
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Mar 04, 2013 | Bosch SMS63E Dishwasher
My dishwasher Bosch SHEAR55UC show E24 on screen , didn't work all of process ?
Hi.
E24 is draining error:
Turn off the appliance. Check drain well and filter for blockage. Clean drain. Check drain hose at the back to make sure it is not kinked. Dry water from inside the appliance manually (with power not connected). If that does not fix the problem, then pressure switch in the drain system is usually responsible. The part to be tested are pump, pressure switch and drain lines.
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher has e24 error code and does not run...10 mths old?
Aug 22, 2009 | Bosch Dishwashers
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Owen Barnes
