Question about Kenmore Energy Star 44092 Front Load Washer
Making a lot of noise
Sounds like a broken drive belt inside
  • 4 more comments
  • Paddy Brown Dec 10, 2012
    Dont know ther number it only says energy star
  • Richard Roth
    Richard Roth Dec 10, 2012
    Look inside the door are for the model number.
    hi thats great the model number is 41744142400 (looks like 11/04 purchase date)
  • Richard Roth
    Thanks for the model number. Could you please describe the problem you are having a little better?
    a lot of banging coming from the drum towards the end of the cycle also some at start of the wash, washed two extra large beach towels during the cycle a lot of metal sounding noises
  • Richard Roth
    Remove the top and spin the drum to see if the belt has split. There should only be 2 or 3 screw on the back of the top.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
Does not spin?
I can only guess that the drive belt has finally broken .call your local repairman
Sep 22, 2015 | Washing Machines
Drum won't go round, machine makes lots of noise
Sounds like the drive belt has slipped off the drum or broken.
Mar 22, 2011 | Zanussi TC7102W Electric Dryer
I have a 1991 mitsubishi 3000gt and it wont start. the motor turns but not sound of it even trying to start like turning over. i see the belts move but no sound as if its even starving for gas just belts...
http://www.fixya.com/cars/r7030578-engine_turns_over_but_wont_start
Here is a link to a tip I wrote nate. It sounds like your timing belt slipped a tooth or ten. Or it may be broken. Does the starter motor seem like its turning the motor much faster than it normally does? You say that you can see the external drive belts turning, if this is true then your starter is engaging correctly. If your timing is off, or belt is broken, the engine will not make compression. Put your hand over the intake while someone cranks it to see if you feel that intake stroke pull on your hand. Read my tip in the link above for lots more info.
Nov 28, 2010 | 1991 Mitsubishi 3000GT
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
Sounds likethewater pump pulley makes noise when
It sounds like you have a loose or worn alternator belt
(same belt drives water pump) That would explain the
screeching noise and the battery light on when wet.
Check the belts for tension and wear on the inside of
the belts(cracks or pieces missing) if you're going to
change the belt or belts yourself, thats the best time
to check the pullys and make sure they are tight and
spin true. Hope this helps.
May 16, 2010 | 2006 Hyundai Sonata
Noisy
1. Your tires maybe low on air
2. The tires need balancing
3. Since your care is FWD, make sure you check to see that you don't have any broken boots on your axles. The lack of grease on those joints will cause a lot of noise. Almost like a moaning, it gets pretty annoying
Hope that helps!!
Feb 06, 2009 | 2002 Chrysler Sebring
Grinding noise usually at idle
most of times its belts which makes noise because of dry just put little bit greace inside of belts it will stop noise but remember do not put a lot just little bit.
Jan 09, 2009 | 2001 Honda CR-V
Drum doesnt turn... motor fine.
From your description I would suspect a broken belt although I am unfamiliar with your model. Once the belt [which transfers drive from the motor to the drum] breaks, it would'nt matter how well the motor runs, it can't turn the drum.
Hope this helps!
Oct 08, 2008 | Bosch Axxis WTA 4107 Electric Dryer
Washing Machines Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
