Question about MSI K9AGM2-L Motherboard
When booting, I get a black screen
When I push the power button the computer starts up, but then I have a black screen. Then when I shut down the computer, I have to wait and then try again, but it stays black.
  • Reusboem Dec 09, 2012
    I tried putting the cmos jumper to 2-3 and then back again. I took out the cmos battery for a while,
    I tried also with a srew shortcutting the power on/off button. It won't help.
    Scholar:
  • 156 Answers
Motherboard faulty. need repairs
Posted on Dec 12, 2012
3 Suggested Answers
SirHanz
  • 145 Answers
SOURCE: MSI problems
Hmmm.., what is your configuration? RAM, drives/video cards/ operating system?
Posted on Jan 30, 2008
  • 6 Answers
SOURCE: keeps turning off
Hey! i had the same problem after i took the computer apart for a clean!!! What happened is that when i took the heatsink off the cpu, the thermal paste had fallen apart a little and i put it back on.... to find computer booting up for about 3 seconds then turning off. i think that when you fire the comp up it turns on the cpu causing it to overheat and shut itself off, just cleaned off old paste and put on some new paste and it fired up! hope this helps you! sorry bout the slight delay!
Posted on Dec 12, 2008
My Acer Chromebook 13 will not power on or charge so can anyone help me with my problem?
try this: remove battery, remove power cable, push and hold down the power button for 1 m (over 60s) do not short time. release the button, insert the power cable. wait 10s then push and hold power button till you see any lite flash release and see if you boot.
some time the static is built and that causes failure to start.
above should clean any static and allow reset of power adapter to function. if yes,. then once you shut down . insert the batter and ;et it charge for 3 mins.. then try to start.
Apr 02, 2015 | Acer CB5 311 T9B0 Chromebook 13 3 inch...
10 inch table sometimes will not go to the shut off choice when I push the button I get a black screen
A short push of the power button puts it to sleep and you get a black screen. A longer push of the power button will show you the screen with the option to power it off.
Feb 01, 2014 | Proscan Computers & Internet
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Acer Veriton M498g - ui3540c won't start
Need more info, Give as much detail as you can. What happens when you push the on/off button? Fan spin? LED's Blink? Any thing on the screen? Sound? Does the computer try to start and a second later shut down? Check the power cord, check the AC outlet? Is it on a UPS? Try AC outlet? Can you get to BIOS or Boot Menu? ETC.
Feb 14, 2013 | Acer Veriton M498G-UI5650W Desktop PC...
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
I have installed windows XP on Acer Aspire 4520 and since it was not booting up normally i installed all the drivers in Safe Mode. Even after doing the same it's not starting normally just a blank (Black)...
your computer your laptop will just shut itself down and get a black screen unexpectedly, which is due to: power overload in the AC adapter, overheated processor / clogged fan, overheated battery, pushing the power button, Windows telling it to, the BIOS telling it to, loose wires (especially the power cord), or intermittent short circuits. The most common problem is cooling. the battery should be removed from the laptop and allowed to cool to room temperature before attempting to use again.
Oct 26, 2010 | Acer Aspire 4520-5141 Notebook
Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Mar 09, 2009 | Dell Inspiron 5160 Notebook
Start up problem
option1:- choose the option called safe mode. the first option. just log in and stay for a while in there and restart your computer.
option2:- choose the option start up windows normally.
Jun 18, 2008 | Compaq Presario 700 470024-192 Notebook
MSI K9AGM2-L Motherboard Logo
179 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
