Question about Acer TravelMate Computers & Internet
All drives reformatted. cd will not read anything. only outboard floppy drive will communicate with Acer 2420 How to restore
  • Acer Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it.
If still no joy
It might be past its use by date
Posted on Dec 08, 2012
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: How to install operating system on laptop with now cd-rom drive or floppy
Did you change the '1st boot' drive to the optical drive?
If you haven't, you need to enter the BIOS setup and change from C: to whatever your optical drive is named and then change it back once the operating system is installed on the C: drive.
Posted on Oct 11, 2008
gripfitter
  • 557 Answers
SOURCE: how to reformat without cd drive
If you have usb ports you can connect a cd drive externally. CD external drives are available most anywhere and not very expensive.
Posted on Sep 22, 2009
SOURCE: My Acer Aspire 5100-3357 DVD Drive cannot read dvd but cd is ok
you need to change with new one no other choice.
Posted on Nov 20, 2009
Dell 1525 dont maneger is dosent see in the screen how i reformat
Reformatting the hard drive of a computer is sometimes an unavoidable task. Whether you're an IT professional or a private user, there are times when the hard drive has to be totally wiped. These reasons range from reallocating a computer to another user, selling it or donating it, installing a larger internal hard drive or even just to eradicate some flaky behavior. Unless the computer is ancient, reformatting a Dell laptop is a moderately easy process.
1. reformat-dell-laptop-1.1-800x800.jpg Damaged hard drive is a reason to reformat
Back up any data on the PC that you plan on saving. This can be accomplished by using burnable CDs or DVDs, attaching an external hard drive, using an online backup process or hooking up to the corporate backup server.
  • 2 reformat-dell-laptop-1.2-800x800.jpg Older flavors of Windows include a bootable floppy Set the boot order on the laptop. This tells the computer the order that it looks for a bootable disc. The default is the C: drive, but this can be changed by holding down the Delete key while booting the computer. If you're using a floppy, which is common with early versions of Windows, select the A: drive. If you're using the CD or DVD, then select that drive (usually the D: drive) by using the up and down arrow keys. Save your preference and exit.
  • 3 reformat-dell-laptop-1.3-800x800.jpg A software restore CD Insert the media (floppy or CD/DVD) into the computer, and then reboot. Select reformat and install, which will erase all the data on the drive and install a fresh copy of Windows.
  • 4 reformat-dell-laptop-1.4-800x800.jpg 2.5-inch internal hard drive Keep an eye on the process, as earlier versions of Windows often require manual intervention such as selecting options, or pressing the Enter key at certain times. More recent versions of Windows are typically autorun.
  • 5 reformat-dell-laptop-1.5-800x800.jpg Disk image utility Follow the prompts during the installation and after rebooting it. Use the restore CD to install any additional drivers and utilities. Run the Windows updates, and if you're planning on keeping the computer (or assigning it to another user), then install any necessary applications and data files, and configure the preferences, email and printers.
  • I hope you find it very helpful. Thank you for using fixya.
    Aug 15, 2011 | Dell Inspiron 1525 Laptop
    ACER ASPIRE 3750G 13.3", reformat.
    when you turn the unit on hit Alt+F10. This will access the acer recovery partition from which you can restore. This is provided you didn't replace the Hard drive or wiped the drive yourself
    Aug 02, 2011 | Acer Computers & Internet
    I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
    Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
    If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
    They may have a restore floppy if you need it too.
    One for "recovery files" and one for "OS Boot"
    AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
    Restore CD should do it all though.
    If no restore CD - have Win98 CD?
    if Harddrive partitioned and formated - Just do 1
    1. boot from Win98 CD.
    Partition n Format
    2. Choose boot to DOS (puts u in virtual drive A)
    AT PROMPT
    3. Type drive letter of CD ( C: D: or E: )
    4. Type CD Win98
    5. Type Fdisk ( to partion drive)
    reboot n do 1 + 2
    6. Type format C: ( I do this to ckeck drive for errors)
    OR
    JUST Boot from CD and follow install instructions.
    1 to 6 for if you have problem with Win98 CD setting up Harddrive.
    Apr 04, 2010 | Compaq Presario 2140US Notebook
    Acer aspire 7520 totaly restoring from blank screen that as
    In case of computer have crashed due to operating system , the computer could access the floppy drive or any other external media drive including CD, USB drive. There should be POST once you power the computer on . The black screen sound like hardware problem, so you must check the problem in any addon cards, cpu, motherboard, power supply to access the floppy disk.
    Sep 14, 2009 | Computers & Internet
    Disc read error occoured
    This can occur as a result of any unreadable drive that is in your boot sequence not reading. Remove all media from the machine(CD, DVD, Memory Card, Flash Drive, Floppy Disk, Printer with memory card slots), then try booting again.
    If that doesn't work, chances are your hard drive is damaged. It may only be minor logical damage or could be serious hardware damage. That is more difficult to assess via subjective analysis but could be sent to a pro for assessment if you have files you require on the drive which are not backed up.
    If this is the case and you do not have anything important on the drive or if you have your files backed up on a second source simply replace the drive and re-install your operating system, then restore the backed up files and move forward.
    If you require any additional info or advice, just ask
    Chris
    May 17, 2009 | Acer Aspire M3641 Dual Core E2200 PC...
    How to reformat samsung s600 without using floppy disk
    go to bios set up then your first to boot is the cd rom drive ok.
    May 01, 2009 | Computers & Internet
    Wiped clean cannot reload windows
    Are you using a floppy or a disc? Your CD rom or disk may be faulty. If you have another copy and/or another cd rom drive try that. Also reseat the memory sticks. Lastly it all of this fails your hard drive may be the culprit...
    Apr 20, 2009 | Acer Power FH PC Desktop
    Distructive reformat
    you needs to use a bootable disk or floppy disk to proceed reformatting the drive before installing the operating system to the computer.
    Mar 15, 2009 | Acer Aspire T180 PC Desktop
    Wont start up
    Sounds like you have a CD or DVD in your CD or DVD drive, or if you have a floppy drive, a floppy in it.
    If these are empty, Put in your recovery CD and see if it reads that.
    Jul 17, 2008 | Acer TravelMate 212T Notebook
    How do you reset Acer Aspire T180-GB7Z PC
    Perform a system recovery:
    Does not come with recovery cd's - there is a program that allows you to burn the disks or
    recover.
    3 ways:
    1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
    click on Restore at bottom then "Restore to factory default settings"
    2. Or click on Burn disks instead of restore
    3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
    End User Technical Support and Service (USA only)
    For end user technical support, spare parts and service: 1.800.816.2237
    Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
    Computers & Internet Logo
    55 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
