Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series model 110 82874130 is leaking under the bottom. How to fix this
Stock number 15522
jtate9
  • 68 Answers
SOURCE: Kenmore Heavy Duty 70 Series Model 110 water leak
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore 70 series
The following link explains how to replace a pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
The pump is only held in place by two retaining clips. Once the clips are removed, the pump (with hoses still attached) pulls directly off the motor shaft. NOTE: If the pump is leaking, it is NOT repairable and requires replacement. These pumps are sealed units. Replacements can be ordered on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offere competitive pricing so shop all three for the best price. If you require addtional assistance, please let me know. I hope this helps you.
Posted on Jan 09, 2009
danromarris
  • 101 Answers
SOURCE: Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Posted on Jan 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
Honda HRR216VK
http://www.searspartsdirect.com/partsdirect/part-model/Honda-Parts/Walk-behind-lawn-mower-Parts/Model-HRR216/1795/1500600/P0510128/ 34aa7d01-b4cc-4610-b618-fe9cb9f2d509.png 1
on diagram CarburetorPART NUMBER: 16100-ZM0-803
Substitution: 16100-Z0L-023 Screw PART NUMBER: 93500-05006-0H
$2.19
In stock This item is not returnable. Qty: ScrewPART NUMBER: 16016-ZG0-W00 $10.97
In stock Qty: ScrewPART NUMBER: 16029-ZG0-901 $16.99
In stock Qty: NozzlePART NUMBER: 16166-ZM0-003 $20.24
In stock Qty: Main jet #60PART NUMBER: 99101-124-0600 $10.24
In stock Qty: ValvePART NUMBER: 16155-ZM0-003 $21.24
In stock Qty: FloatPART NUMBER: 16013-ZL1-003 $29.99
In stock Qty: GasketPART NUMBER: 16010-883-015 $9.74
In stock pd_0071_550_16010-883-015?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: ChamberPART NUMBER: 16015-887-782 $33.66
In stock Qty: ScrewPART NUMBER: 16024-ZE1-811 $19.26
In stock Qty: ScrewPART NUMBER: 16028-ZE0-005
Substitution: 16028-ZK7-S91 Carburetor gasket PART NUMBER: 16228-ZL8-000
$3.99
In stock This item is not returnable. pd_0071_550_16228-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Gasket, carburetorPART NUMBER: 16221-883-800 $2.99
In stock This item is not returnable. pd_0071_550_16221-883-800?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: GuidePART NUMBER: 19650-ZM0-000 $12.74
In stock pd_0071_550_19650-zm0-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Insulated carburet...PART NUMBER: 16211-ZL8-000 $3.99
In stock This item is not returnable. pd_0071_550_16211-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: Gas insulatorPART NUMBER: 16212-ZL8-000 $4.48
In stock This item is not returnable. pd_0071_550_16212-zl8-000?hei=60&wid=60&op_sharpen=1&qlt=100 Qty: TransmissionPART NUMBER: 20001-VG3-B03 $279.74
In stock
May 21, 2014 | Garden
Should I buy a new washer? I have a great Kenmore, Heavy Duty, 70 Series, model 110, serial number C83193200. Yes, it was made in 1983 and now leaks water from the bottom front onto the floor.
It could be a dry rot hose or the pump could be leaking might be an easy fix it depends whether you want to repair it or spend allot of money on a new dryer are u pretty handy i could assist you on how to fix it .
Nov 24, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Built in stock no. 15685. dishwasher box will not open. no. problem with water. Maria Musolino
Hello, mmusolino
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Aug 16, 2011 | Kenmore 15522 Built-in Dishwasher
Washer stops after wash cycle, does not cool down and drain water. I turn the knob to rinse it starts up again but does not drain the water. Help
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Series numbers (70, 80, 90) only designate the number of "Bells and Whistles" that a washer has and don't reflect the model number.
See the following for where to find the model number:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=c73289e58485c8752675ae1a35ff796b
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Jan 13, 2011 | Kenmore Washing Machines
Dishwasher won't start
check to make sure that you have power at the outlet ( under sink ). if you do in fact have power ( 120VAC ) at the outlet then it sounds like the door closed switch might not be working correctly.
c...
Dec 31, 2010 | Kenmore 15522 Built-in Dishwasher
Dishwash wont start control was changed it worked for 10 min and stopped again
Sorry to read about your problem, I hope this helps you out.
you must have had another problem, i suggest you can a service company, and stop throwing parts at the machine. you will save money in the long run..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Kenmore 15522 Built-in Dishwasher
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Leaking from the door around hinge?
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Kenmore 15522 Built-in Dishwasher
I got a spot light vector part#vec141y and i have urgency to buy the charger
You can purchase the charger from Black and Decker, they purchased Vector in 2006, here is the link; http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69415&tid=15522
Mar 09, 2010 | Camping, Backpacking & Hiking
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
