Question about Autodesk AutoCAD 2006
When I try to utilize a couple of AutoCAD 2006 commands, they do not respond (all I get is a blank command line). Is there a repair sub-program on my CD that I can use or do I have to uninstall and reinstall the program?
  • 242 Answers
Questions:
Which version of Windows are you using?
Are you using 64 bit AutoCAD on a 64 bit computer?
Posted on Dec 08, 2012
4 Suggested Answers
randy320sgi
  • 121 Answers
SOURCE: Autocad 2006 is not showing toolbar icons and labels
tushagargus, Have you tried to use the pull down menu for toolbar?  let me know if you don't restore the toolbars, there are a couple of ways to load them without having to reinstall. randy320sgi
Posted on Jan 30, 2009
  • 13 Answers
SOURCE: Inserting a picture
xref or raster image
Posted on Apr 07, 2010
  • 2340 Answers
SOURCE: I am not able to
Reinstall & unistall the programme
or
Use the System restore Utility to restore it to the point before you install the programme.
Hope it helps.
Posted on Feb 03, 2011
My valuable .dwg file has trouble
If a file cannot be opened, take the following steps for repair dwg
In case it can't be effective, then you have hard issue, see and learn more professional articles, guides and etc.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-repair-AutoCAD-Installation.html
http://www.thesourcecad.com/recover-damaged-or-lost-autocad-files/
https://dwg.recoverytoolbox.com/
  • RECOVER command
    --Recovers a selected drawing file
    --If successful, open and run AUDIT command
    --Evaluates drawing integrity and possibly more error correction
    --Set system variable AUDITCTL=1 to create a report of audit results
  • RECOVERALL command (introduced in AutoCAD 2008)
    --Attached and nested xrefs are also opened, repaired, resaved, and closed
  • INSERT and EXPLODE
  • Start a new DWG with no template
    --Run INSERT and selected the corrupted drawing
    --Check the "Explode" option
Mar 20, 2018 | Autodesk Computers & Internet
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
Load application autocad 2010
I think some files of this software are corrupt in program files. You need to upgrade the software with previous settings.
Jul 31, 2013 | Microsoft Windows XP Professional
My laptop keeps going to the start up screen and blanking
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 20, 2012 | HP Compaq 6910p Notebook PC PC Notebook
Electricity went out. rebooted computer. monitor screen is blank. when I press the input button on monitor, the sign on screen pops up for a sec then blank again
Try removing the power cord then press and hold the power button for 30 seconds. Put the power cord back in the try rebooting.
If it fails try to run the Check Disk Utility.
May 03, 2012 | Computers & Internet
What should i do if i start my computer and i get a blank screen with a cursor
Run the Check Disk Utility.
Apr 29, 2012 | Acer Aspire one A150-1447 Notebook
My computer will not shut off---screen blank except the cursor
Unplug it. Works every time.
Run the Check Disk UtilityTo run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Apr 14, 2012 | IBM Computers & Internet
I am not able to uninstalled autocad 2006 through Add/remove programs. "Fatal Error while trying to uninstall Autocad 2006.
or
Hope it helps.
Feb 03, 2011 | Autodesk AutoCAD 2006
Autodesk AutoCAD 2006 Logo
66 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
