Question about Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea
Won't go forward or bacward
When I hookup battery,when I go forward or backwards,it won't go and it alarms.
3 Suggested Answers
gfreed100
  • 60 Answers
SOURCE: my scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Posted on Jul 30, 2012
  • 20 Answers
SOURCE: WHEN I PLUG INTO BATTERY,CAN'T GO FORWARD OR BACKWARD,IT ALARMS WHEN I DO THIS
At times problems which are related to engine or mechanical issues do not only mean your bike engines are in any mess. The problem can arise from different reasons one being exhaust systems. I advice you be checking your bike's mechanical components as frequent as possible so as to avoid inconveniences..
Posted on Mar 08, 2013
Jammed it, removed all paper, now it won't start
Your shredder may be jammed with shreds of paper mashed into the mechanism. Access the mechanism and prepare to remove all ground-in residue bit-by-bit.
Oct 20, 2017 | Office Equipment & Supplies
hi, is it a consent buzz if so that because it's in freewheel mode , the lever located near the rear of the scooter, if that's not the case chec kthe switch located near this lever..
Dec 07, 2012 | Shoprider Mobility Products, Inc. Hero...
The car won't go forward or backward
Lift up all the wheels one by one, rotate each wheel and check which wheel resists to rotate. Disassemble the jammed wheel and carefully examine to see why is it so.
Grease the caliper pins, free up the pistons and reset the brake components.
Dec 03, 2012 | 2001 Toyota Echo
Transmission problems for 98 dakota
Pull it out & have it rebuilt
Can pull the valve body & clean, if you like
doing that kind of work,doubt it will be the total
solution
Nov 25, 2012 | Cars & Trucks
Starter just clicks won't turn over
your starter is the 1 which is damaged n if they say or u check it n find that its gud then its your terminals they are loose somewhere
Oct 23, 2012 | Cars & Trucks
Why won't 2002 maxima seat go forward or backward? Can hear the motor and nothing stuck on track
I would say the cables or rods that go from the motor to the gears are broke or stripped.
Aug 08, 2012 | 2002 Nissan Maxima
My Dyson falls backward & won't stand up - what's wrong?
Hi Kay,
I'm sorry to hear you're having difficulty with your DC18. If the stabiliser doesn't seem to be locking the machine upright, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will be useful if you can have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC18 all floors Bagless Upright...
Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea Logo
37 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
