Question about Badger 5 All Insinkerator 76037h 1/2 Hp Feed Garbage Disposer Disposal Black
Reverse polarity garbage disposil
Motor started running backwards
  • 5,245 Answers
1) Each motor can be reversed if wiring is changed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) How did your motor wiring get reversed?
Posted on Dec 09, 2012
Can you hook up a fuel pump incorectly so its running backwards
Yes it is a DC motor, so if you reverse the polarity it will run backwards.
Sep 26, 2016 | Cars & Trucks
Need wiring diagram for a single phase brook motor n a broomwade compressor
I suggest you contact Brooks if they are still in business. If not there is lots of motor info on the net.
Traditional single phase motors are fairly straightforward and similar to each other. The main thing to watch out for is to have the start and run windings wired with the same polarity. If the polarity is reversed on either winding the motor will run backwards.
Feb 06, 2016 | Air Tools & Compressors
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
How to solve reversed polarity in 1996 Geo prism
a perfectly running car>
please do say
what is wrong.
and what is reversed. we can not guess that.
let me guess. the cigarette lighter shows reverse polarity.
  1. car runs , your meter is backwards.
  2. engine dont run , battery installed backwards (lugs)
Jul 08, 2014 | Geo Prizm Cars & Trucks
Why is my1 1/2 hp sprinkler pump pumping OUT intake with no elec changes?
I am not sure, but DC motors will run backwards if the polarity of the incoming voltage is switched. I see this is an AC motor but they always run forward no matter the polarity, unless the polarity is reversed to the right wires inside the motor. The second link has a discussion on exactly how to do that. Thus it may have your answer, that those wires got switched somehow on your motor. Which means you need to buy a new motor.
http://www.aqua-man.com/row_num.asp?Ic=1133
http://cr4.globalspec.com/thread/26099
May 29, 2014 | A.O. Smith SQ1102 Pool Pump Motor
The hood fans seem to be running backwards. how is that possible on an ac motor?
any ac motor can go in reverse. The direction is chosen by the direction of the start winding. reverse the polarity of the start winding where you see the 2 extra crimp connectors where you wired the motor just swap them
Nov 27, 2013 | Kenmore Kitchen Ranges
What to do when you reversed polarity on new battery
If you installed the battery backwards a lot of times the only thing that will happen is the starter will run backwards. Remove the battery, test for full charge, then reinstall properly. Usually no damage has been done. Start motor and check the function of all electrical components and check the charging system to be sure.
Nov 24, 2012 | Toro Power Lawn Mower
Motor runs backwards (forword is reverse-reverse runs forword)
is this an electric motor? if so, you can just switch the polarity around. meaning connect positive to negative and negative to positive. hope this helps!
Feb 17, 2010 | Boating
Motor Running backwards.
flip ur wires on motors. just reverse ur polarity.
Jan 29, 2009 | Reddy R115DT Oil Filled Utility Heater
Badger 5 All Insinkerator 76037h 1/2 Hp Feed Garbage Disposer Disposal Black Logo
481 people viewed this question
Top Badger Home Experts
john h
Tom Chichester
Are you a Badger Home Expert? Answer questions, earn points and help others
