Question about Compaq Presario CQ61-411WM
My Presario CQ61 will not power on. Power supply is good. LED at power plugin comes on when power is applied. LED on front of laptop blinks but laptop will not pwer on.
  • Scott Conner
    Scott Conner Dec 28, 2012
    Replaced battery. Working now.
    New Friend:
  • 3 Answers
You need flash bios
Posted on Feb 20, 2013
My compaq presarion won't start up and the led in the charger hole won't light on
Try removing the battery and only using AC power. If the power
LED on the power brick does not come on then replace the power supply. If it works with just AC then replace the battery. If it still doesn't work, warranty replace the computer.
Mar 28, 2014 | Compaq HP Presario CQ61-314TU Laptop...
The light charger hole is not on
Posting the same thing twice is annoying and counter productive.
Try removing the battery and only using AC power. If the power LED on the power brick does not come on then replace the power supply. If it works with just AC then replace the battery. If it still doesn't work, warranty replace the computer.
Fit my Compaq Presario CQ61?
accu Compaq Presario CQ61 100 percent compatible with you Compaq Presario CQ61. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/compaq-presario-cq61.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
Won't power up
This indicates your power supply adapter is bad, go to www.ebay.com Type: make and model of laptop, refine search to power supply.
May 20, 2012 | Compaq Presario CQ61-310US Laptop
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
Does cq61 laptop works without battery
I would assume that the wire/power supply is more likely to be the problem. Even if the battery is completely shot, most laptops will start if the power cord is plugged into the outlet and the laptop is turned on. You should check on replacing the power supply / power cord. Buy it from a store that takes returns with no questions asked. I've even bought one, tested it in the store, (after asking in advance if I could do so). This is a good idea if you live 40 miles from the place it's purchased.
Feb 21, 2012 | Compaq Presario CQ61-310US Laptop
Compaq CQ61 does not power on. Power supply is good, I tried it on another similar laptop and it works. I tested the power connector independently for continuity and it checks out as good. When I plug the...
I think its already a problem with the Motherboard, Processor, Video Card or Memory. Blinking lights upon plugging the machine means there is a failed Hardware. I have known those problem because I've been support for HP way back and those are the problem for the CQ61 model. If happens your machine is still in warranty better call HP and have it service.
May 09, 2011 | Compaq Computers & Internet
Hey. i have a compaq CQ61 notebook and am having troubles turning it on. Whilst using it casually e.g. the internet and powerpoint it just shut off. When plugged in to the power supply, the light glows on...
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario Notebook
Compaq Presario CQ61-411WM Logo
350 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
