Question about Sewing Machines
I have a Kenmore 385 model and I can not make it zig zag????
I can not get the zig zag or reverse to work on this machine, it is old and I have not used it for a long time
  • Sewing Machines Master
  • 7,365 Answers
Even an oldie is still a goodie,, when a sewing machine has not
been used for a long time the grease and oil can become yecky
and it sounds like the machine needs to be serviced with new grease
and oil and see if that help the machine, also having the zig zag
gear or cam checked would be a good idea.
Posted on Dec 07, 2012
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
Kenmore ultra stitch 6 Model 13402
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
May 26, 2014 | Sewing Machines
How to install a Kenmore monogramer to a Kenmore zig zag machine
You are replacing the presser foot with the monogramer and you will need the very specialized instructions for it's proper use.
Jan 30, 2014 | Sewing Machines
Kenmore 385.12490
Check the position of the Button Hole Stitch adjuster that is directly under the stitch length control. It looks like a flat head screw and should be straight up and down for normal sewing.
Jun 30, 2013 | Sewing Machines
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
My zig zag is not working properly
no i have not received an answer to the problem from no one
neither anyone having a repair book on this machine, anyway the reason i cannot purchase a plan is because i dont have a crdit card.
Apr 08, 2008 | Sewing Machines
Feb 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
