Question about Mitsubishi Televison & Video
Screen shakes I have a 72" tv. When I power it on the screen shakes for a couple minutes and then stops on its own. It happens when playing dvds as well. What could be the problem? Is it something I should attempt to fix or call in a professional? Thank you for your help.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
An answer or advice would depend on knowing the model number of your set.
Posted on Dec 07, 2012
yankeegurl
  • 121 Answers
SOURCE: TV Goes Blank after 5 minutes
If the lamp indicator stays red then you do need to replace the lamp if not without a service manual for your tv its difficult to trouble shoot the problem but if you don't have one you can get one at this sight along with free online tech support
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Sonykp57hw40
sounds like the blue CRT is shorted and thats what is shutting down the set.
Posted on Jun 07, 2008
SOURCE: TV wont turn on
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Posted on Sep 19, 2008
SOURCE: Digilogic TV and DVD combi
Clean the laser lens
Posted on Nov 07, 2008
SOURCE: TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Posted on Dec 07, 2008
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
Hi I have a Bauhn DVD TV from Aldi approx 1 year old. It's played DVDs great until I watched a movie on a USB. Now it won't recognise the DVDs and shoots them out after making a clicking noise. Sorry...
Hmm... I think there are many possible answers to this.
- Try to select DVD manually.
- Try to add a DVD while your USB stick is attached.
- Try to pull the wall power cable. Wait for 20 minutes, then plug it in and start the DVD player.
Very strange... Do you have a guarantee?
Jul 19, 2014 | Televison & Video
My Trinitron's mostly fine, though it's a few years old, but it has a strange display issue. It's almost as though the picture is "zoomed in" about 8%, cutting off about 1 to 1 1/2 inches of...
This problems u are having it is not the causes by the tv,because ur tv it is a analoge CRT tv,don't have this functions zooming in or out or the problems just causes only 8% cutting off edges of the tv pictures only.If the problem it is happening to ur analoge tv it will have no vertical hold at all.The devices u are connected to the tv and using have zoomming in or out buttons or ajustment buttons of the sizes of the picture on the screen.Used the devices remotes controls to readjust ur zooming or pictures sizes adjutment.
May 04, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
Philips MX3800D home cinema dvd play stops after 10 mins.
If this happens with all DVDs you need to replace the player
Jan 26, 2010 | Audio Players & Recorders
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
