Question about GE Dishwashers
Dishwasher heat does not get cut off
The heat on my GE Monogram dishwasher model ZBD0710N0SS seems to not get cut off. It resulted into burning of the spray arm, silver basket and some other parts. I have to cut off the main switch to stop the heat. I got a service technician to have a look at it and he suggested replacing the control board, heating element, spray arm (its burnt). I am wondering if this is a fair amount of work and if I can do it myself. I tried to look for manuals and instructions on replacing the parts but could not find it. Does anyone has any experience on it?
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 170 Answers
SOURCE: Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it.... (
this is one continuous can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
Posted on Mar 27, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Posted on Apr 24, 2009
  • 9 Answers
SOURCE: GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
Posted on May 18, 2009
SOURCE: GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Posted on Nov 12, 2009
Why does my GE Monogram dishwasher keep blinking in rinse hold mode
either the water will not drain due to bad water pump or restriction, clean clear or replace
Aug 21, 2014 | GE Monogram® ZBD6880NSS Stainless Steel...
My dishes in the top rack don't get clean. The dishwasher is a ge monogram zbd6800kss. i believe the spray arm does not spray water to the top shelf. any help is appreciated
Hi tomcl244,
The spray arm may be clogged. Please look at my tip below on how to clean it, as well as nifty things to do to keep your Dishwasher running smoothly:
Kind Regards :-)
If this solution helped you, please rate it
Jul 18, 2011 | GE Monogram ZBD6880K Dishwasher
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting
Aug 03, 2010 | Dishwashers
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Apr 04, 2008 | GE 24 in. Monogram ZBD6880KSS Stainless...
I think I had and now have again the same issue. I called a repair man who replace the entire control panel. He state the moisture caused it to blow out. The moisture???? it's a dishwasher. Well a year later the problem has returned. I can only use one setting at this point.
Dec 28, 2007 | GE Dishwashers
Dishwashers Logo
37 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
