Question about Progressive Dynamics Inteli-Power 9100 Series 45 Amp Converter Charger
Inteli power 9100 converter schematic
There is a component burned inside the case it was about 3/4 inch in diameter and flat, colored gray with no numbers on it. it looks like maybe a VDR or surge suppressor. Looking for technical info or even a schematic.
Powers on and then the screen is light gray color but all buttons Menu-Input-Vol-Channels will not function.The Tv only powers on and powers off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 24, 2016 | Televison & Video
I replaced clock panel turn power on nothing is there a code
If no display---you may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps.
May 12, 2015 | Kenmore 4888 Elite 30" Built-In Microwave...
How do I access the fuses
You may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps. Should be a few screws around control panel to get it loose.
May 11, 2015 | Whirlpool MH1150XM Convection/Microwave...
How many gallons of water will it take to fill 160' of 2"pipe
look up inside diameter of your 2' pipe
area inside a circle = 3.1415 (pi) x radius squared
for example if inside diameter of pipe is 1.75", then radius is half or .875
radius squared is .7656 x 3.1415 = 2.4 square inches
160 feet pipe = 1920 inches
2.4 square inches x 1920 = 4618 cubic inches
Then convert cubic inches into gallons:
http://www.metric-conversions.org/volume/cubic-inches-to-gallons.htm
If water is hot, then that can affect final calculation
Gene
Aug 26, 2014 | Water Heaters
Catalytic converter needs replaced, want to do it myself but need a set of instructions or a manual. thought i could find one on the internet but not having any luck.
Visit your local library and take a look at their motor manual collection for general instructions for this procedure.
Mar 03, 2011 | 2003 Toyota Highlander
I need to know how to change all my vacume hoses on my car can you tell me where to find them
In most cases they are all located in the engine compartment which would be the area under the hood of your vehicle, some are located inside the vehicles cabin area under the dashboard feeding vacumn to the heater/air conditioner systems they may be black rubber or various in colors inside the car and out, they are all very small in diameter rubber and some plastic with Tee's inserted to make vac. transferes to other components , unless you are changing the power brake hose, and the pcv lines they are 3/8" or more, all others should be less then 1/4" diameter and various lengths.
If you want original equipment go to the dealer but the vehicle has to be less then 10 years old to get these parts if at all possible, otherwise go to your nearest parts store or wrecking yard if they have a vehicle crashed and in good parts shape.
Have Fun doing Your Adventures in Automotive Repairs....welcome to our world!!!
Aug 27, 2010 | 1994 Mercury Grand Marquis
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
How i can change the feet and inches in excel
Is this what you want?
=INT(A1/12) & "'" & MOD(A1,12) & "''"
This will convert input from inches from A1 to an x'xx" format.
Jul 10, 2009 | Microsoft Excel for PC
Installing mobo
here http://www.nvidia.com/object/designed_by_nvidia_support.html
Mar 01, 2017 | Computers & Internet
Blown Board inside TV
Is it the board with flyback or the green one with the small parts/// also on the label on the back of the tv there is a model number and then in smaller letter there is the model number plus some suffix numbers yx1 or somethig to effectd52w19yx1. thats important in determining part muber.
Feb 12, 2008 | RCA D52W19 52" Rear Projection Television
Progressive Dynamics Inteli-Power 9100 Series 45 Amp Converter Charger Logo
115 people viewed this question
Top Progressive Dynamics Electronics - Others Experts
Are you a Progressive Dynamics Electronics - Other Expert? Answer questions, earn points and help others
