Question about Brother XL3750 Mechanical Sewing Machine
Skipping stitches put new needles and still not sewing
  • Brother Master
  • 7,365 Answers
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Posted on Dec 07, 2012
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
  • 7 Answers
SOURCE: My ls2125i won't stitch
Start slowly, make sure your thread trails are long enough, I had this problem a LOT when I first started using this machine. (mainly because it was my first machine!)
Fabric bulge- Don't try to push the fabric through the machine, let the feed dogs do it. Your job is to guide the fabric.
Thread jumps- Also, like Outdoorsman said, the tension is probably off. On this machine, the tension knob is easy to find. It's the small one with the numbers on it. "0 1 2 3 4-5-6 7 8 9" 4-5-6 are your optimal sewing tensions. I usually sew on 4 or 5, depending on my fabric and type of stitch.
No stitches- Your lower thread may not be being grabbed properly/bobbin case may be jumping out of position. Open the lower case and make sure your bobbin case is secure, and the thread is grabbed properly.
Hope this helps!
~iamtyping
Posted on Jul 31, 2009
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
SOURCE: my brother sewing machine, My
check needle to see if it's damaged-roll on flat surface to see if it roll correctly
adjust top & bottom tension according to operation manual
Posted on Oct 01, 2010
aeroseek
  • 55 Answers
SOURCE: My machine sews straight when set to zig zag and
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
Posted on Dec 12, 2010
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Slant o matic 401g skipping stitches what is wrong
Make sure you are using a brand new needle. A damaged needle will frequently cause skipped stitches. (Changing the needle is the least expensive repair for machine problems!!!!)
There is a lot of information available on the internet.
10 reasons for skipped stitches
Nov 17, 2016 | Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
Oct 21, 2016 | PfaFF Sewing Machines
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
Skipping stitches
Change the needle; it could be blunt, burred, or a ballpoint on a woven fabric would all cause skipped stitches. If you hand wind the machine through a stitch and can hear popping, or squeaking, its blunt, change it.
A sewing machine needle needs to be replaced after 4-6 hours of sewing, so a new one for each project is a good rule of thumb.
This means that you are putting in the right sized needle for the project too, not just using what was in there from last project.
Invest in a packet of needles in every size, ball point and sharps, microtex, leather, and denim.
there is good information on needles on http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm too.
Apr 06, 2011 | Sewing Machines
Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
May 01, 2009 | Singer 5050 Mechanical Sewing Machine
Open Questions:
See all Brother XL3750 Mechanical Sewing Machine Questions
Brother XL3750 Mechanical Sewing Machine Logo
64 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
