Question about Water Dispensing & Filtration
Hybrid Water Softener Model No 625.385200 purchased in Oct 10, 2012 produces a rotten egg smell. Very strong when we leave and turn the house water off for 7 + days. What can be done to get rid of the rotten egg smell? This did not happen before we had the water softener. It is noticeable on both the cold and hot facets.
3 Suggested Answers
housejess
  • 317 Answers
SOURCE: 2 month old Lochinvar Electric 30 gal heater hot
is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Posted on Nov 17, 2009
rickead1
  • 1998 Answers
SOURCE: smelly water with water softener
Your local home depot sells a product called AFFRESH that is made for front loaders to clean mold as well as stagnant water smells from washing machines. I have also hear other techs suggest vinegar and water but personally I would much rather have the unit smelling nice and flowery smell instead of a vinegary smell. Also it is important to note your drain line should be at least 6" higher then the top of your washer if it were less then the water that is supposed to leave the machine goes back inside the machine thus giveing some a stagnant water smell or like bad eggs.If you have any further questions message me back
Thank you
Rick
Posted on Nov 27, 2011
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Smelly water with water softener
Thank you
Rick
Nov 26, 2011 | Washing Machines
We hyave a Watco water softener odel 844, we or having a odor problem what does this mean?
if you have a smell like rotten eggs you have a hydrogen sulfide problem which you can treat in two ways you can add on a carbon filter that regenerates with either chlorine recomended or an airator system which you will smell on the side of your house you can have your hydrogen sulfide checked to see how many parts per million yuou have in your water
Sep 14, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
My wife and I are renting a house. The landlord told us that the water heater was recently replaced. The hot water smells pretty bad. The landlord says that the fowl smell is due to the anode rod in the...
Hi. Your landlord is correct. Anode rod can produce rotten-egg smell. Ask him if he can replace the "sacrificial" anode rod with "Power" anode rod or zinc/aluminum rod to get rid of the smell. However, you need to decide whether you tolerate the bad smell produced by anode rod or the minimal toxin produced by zinc/aluminum rod.
You can also try to drain/clean the tank first then add peroxide treatment and see if the smell goes away. If you do this method, the smell is more likely to come back if you go on vacation and left the heater unused for several days.
This article explains it better: Why Does My Water Smell Like Rotten Eggs (scroll down to page 2)
Let me know if you need further assistance. Thanks.
Jun 18, 2010 | Kitchen Ranges
Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
Rotten egg smell / sink
Two different problems. Rotten egg smell is sulfer from the water supply, especially strong in heated water. Drain may need to be cabled out.
Mar 12, 2009 | Plumbing
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Water Dispensing & Filtration Logo
57 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
