Question about Remote Start System
2012 honda cr v disarm wire location - Remote Start System
  • Viper Master
  • 625 Answers
The disarm wire is in the driver kick panel, in the harness coming in from the driver door. It's a thin brown wire.
Posted on Mar 03, 2014
2012 Honda CR-V with approximately 30,000 miles on it. Intermittently when I press and depress the brakes I hear a springing noise. It literally sounds like it's bouncing.
Sounds like u are describing chassis springs on the struts or strut mounts. Have it ckd. Simple lube of springs may solve it or chassis svc.
Feb 18, 2017 | 2012 Honda CR-V
Wiring on cr125, no spark
Hi, Todd and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
cr125 no spark
how to fix no spark and wire pit bike
Honda CR 125R 2002 Sevice Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CR125R 2006 Owner Manual
Jan 31, 2017 | 2002 Honda CR 125 R
How to fix electric wing mirror Honda crv
How To Install Replace Side View Mirror Honda CR-V 02-06 ...
? 10:31
https://www.youtube.com/watch?v=tuGFzxCVh7k
May 8, 2012 - Uploaded by 1A Auto Parts
In this video, 1A Auto shows you how to repair, install, fix, change or replace a broken, smashed, cracked, or ...
Replace 2002-2006 Honda CR-V Side Mirror, How to ...
? 14:20
https://www.youtube.com/watch?v=UKLPkZszbrA
Sep 25, 2013 - Uploaded by Go-Parts
Side Mirror purchased from www.Go-Parts.com Links to purchase products: ...
2000 Honda CR-V side mirror replacement - YouTube
Dec 16, 2015 | Honda HRV Cars & Trucks
How do i find what and where is leaking in my car
The first clue is the color of the fluid, the second is location of the spots it is leaving.
Oct 09, 2015 | 2005 Honda CRV 2.2
Where is the rear wiper fluid reservoir located?
Owner's manual should have the location.
Oct 08, 2015 | 2012 Honda CR-V
Grinding noise after starting my Honda CRV 2012
Are you still under warranty? I'd check that first then take to a dealer.
Feb 15, 2013 | 2012 Honda CR-V LX 4dr SUV 2.4L 4-cyl....
2012 Honda CR-V (no navigation) compass keeps blinking wrong direction
I have same issue as Marlyn Paterno and my Honda dealer had it a whole day and could not find issue. So after charging me $150 to check the wiring, they told me it may be my GPS unit. I refused to pay another $200 with no guarantees. They had never seen this issue before where they set zone and then it changed zones and blinks (NE CAL. Or S CAL.) If anyone has any ideas, I'd appreciate it. My 2012 CRV has been doing this since summer 2013 off and on.
Apr 25, 2012 | 2012 Honda CR-V LX 4dr SUV 2.4L 4-cyl....
Remote Start System  Logo
46 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Tre Elkins
Shehu Pro
Shehu Pro
Joseph Gallucci
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
