How to delete old boot? I am using windows 7pro,
How to delete old boot? I am using windows 7pro, and old windows was xp pro, and now i boot manually ,but the time install win7 ,i formatted system drive, but the old boot is still alive, and is on the hard drive, so help how can i remove it? And boot automatically
  • 2,878 Answers
Go to Start > Search. Type MSConfig. Go to Boot.ini. Remove extra partition. Be careful a wrong config will cause boot failure. I would make a back up copy of the file before making any changes.
There is also a chance of it saying to use Boot Manager. Same thing only command line interface.
Posted on Dec 07, 2012
SOURCE: ACER 4720Z
It's very easy. You can switch SATA mode from AHCI to IDE (in Bios) and install XP, or leave AHCI mode, with 'nLite' integrate AHCI drivers into XP installatin files, burn and install... Drivers are not problem, just search in google, even ePower tools are working.
Posted on May 14, 2008
  • 397 Answers
SOURCE: removing windows xp without formating the harddisk
Go to.
Control Panel > System > Advanced > Start Up and Recovery > Settings. near the top of the window you will see Default operating system, just select the one you want to stat first and delete the other.
Posted on Aug 08, 2008
DarkmanUK
  • 94 Answers
SOURCE: recover windows after virus attack
You need to stop the service from running before you go any further...
click start>run type in 'regedit' then navigate to
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
Diable it from running. You can also do this by start>run type in 'gpedit.msc' and looking for the entry there, then disabling it
Once you have done that restart your machine, then look for every file on the HDD relating to ckvo.exe and deleting it. Check your %temp% folder and registry as well. When you think you have all the files empty the recycle bin, delete the key from the registry and restart the pc again.
Check to see if you can access you HDD as normal.
I cannot say for sure if this works, but it it is worth a try.
Do a google search for Malwarebytes' Anti-Malware, there is a free version available, I believe Cnet Downloads have it on their site, install and update then run it, there is a good chance that the program will pick up the virus and remove it for you.
Posted on Aug 11, 2008
buchin
  • 12 Answers
SOURCE: BOOT.INI deleted. How to re-create this file?
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Please rate this if you found this answer helpful. :)
Posted on Dec 28, 2008
sodeep
  • 3267 Answers
SOURCE: On boot computer does not see Hard drives
Chose boot sequence to boot directly from the HDD . Also check if the Hard Disk is OK by connecting it to another PC. Check too that the power cables are snug tight and none of the pins are bent in the IDE slot. Now try booting first in safe mode & if successful go ahead and boot normally....sodeep
Posted on Apr 19, 2009
How to uninstall windows 7
Step 1:
Delete Windows 7 b> Released in October 2009, Windows 7 is the most recent Microsoft Operating system (as of September 2010). It offers several advances over previous versions of windows, including improved media functions and networking. Windows 7 is not for everyone, however, and there are instances in which someone may wish to remove Windows 7 in favor of an earlier version. There are three ways to delete Windows 7, and the method you use depends on how it was originally installed.
b>Back up the data on your computer. Go to the Windows Start Menu. Select "Computer" and right-click on the "C" drive. Left-click on "Properties" and write down the amount of free space on your drive. Close out of the "C" drive properties and go to the Windows Start Menu. Type "Windows.old" in the "Search Programs and Files" box. If the "Windows.old" folder does not exist, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." Right-click the Windows.old folder, left-click on "Properties" and look at the of the folder. Compare the of the folder with the amount of free space on your drive you wrote down in Step 2. The Windows.old folder contains compressed files; if the folder is more than two times the of the amount of free space on your drive, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." For example: If you only have 10GB of free space on your C drive and the Windows.old file is 22GB large, when it expands it may use up the remaining 10GB and then some. Insert the Windows 7 installation disc and reboot your machine. Select the option to boot from CD/DVD when prompted. Set the language, time and location-specific settings and click "Next." Select "Repair Your Computer" from the list of installation options. Select your version of Windows 7 and click "Next." Click "Command Prompt" to open the command prompt window. Type the following commands, and hit the "Enter" key after each: C: Md Win7 Move Windows Win7\Windows Move "Program Files" "Win7\Program Files" Move Users Win7\Users Attrib --h --s --r ProgramData Move ProgramData Win7\ProgramData Rd "Documents and Settings" Type the following commands and hit the "Enter" key after each: move /y c:\Windows.old\Windows c:\ move /y "c:\Windows.old\Program Files" c:\ move /y c:\Windows.old\ProgramData c:\ move /y c:\Windows.old\Users c:\ move /y "c:\Windows.old\Documents and Settings" c Restore the boot sector for the earlier version of Windows with one of the following commands: For Vista, type: D:\boot\bootsect /nt52 c: For Windows XP or Windows 2000, type: D:\boot\bootsect /nt60 c: Type the following commands and hit the "Enter" key after each command: Attrib --h --s --r boot.ini.saved Copy boot.ini.saved boot.ini Close the Command Prompt window and reboot your computer. b> Remove Windows 7 From a Multi-Boot System Boot your computer to the Non-Windows 7 Operating system and back up your data. Go to the Windows Start Menu, select "Control Panel" and click "System and Security." Select "Administrative Tools" and double-click "Computer Management." Enter your Administrator Password if prompted. Click "Storage" on the left and select "Disk Management." Locate the drive or partition that is running the Windows 7 operating system. If you have both operating systems on the same partition, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." Right-click on the Windows 7 partition, click "Format" or "Delete" to remove Windows 7 from that partition. Click "OK" and reboot your computer. b> Remove Windows 7 from a Computer with No Previous Operating System Back up the data on your hard drive and insert the desired Windows installation disk, such as Windows Vista or Windows XP. Reboot your machine and select the option to boot from CD/DVD. Press "Enter" to start the installation process. Hit F8 to agree to the "Microsoft Software License Terms" and select the option to install a new version of the software. Select the C: drive and highlight the option to format and partition the drive. Press the "Enter" key. Follow the on-screen prompts to install Windows. The computer may reboot several times during the installation process. Enter your product key when prompted.
b>
Feb 05, 2013 | Sony VAIO VPCEA25FX/WI E Series 14...
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Formatt win7 to install winxp
when you boot from xp installation cd it should start but if as you say nothing is happening there may be a problem with the cd or the drive. If you're sure it works properly you can always install your existing hard drive (the one with win 7) in another computer and format it then replace it and try again. When you format it you will wipe everything and it will be blank.
Aug 02, 2012 | Computers & Internet
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
I have win 7 and win xp loaded on my lap..How can I delet xp now?
You need to check if there any Boot Information in partition that is used by WinXP. In this situation best way is to reinstall Win7, and format all your partitions as you want in Win7 installations process.
Apr 18, 2010 | Microsoft Windows Vista Ultimate Edition
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
