Question about Zenith Z60PV220 60-inch Plasma TV
How to replace the light
It need a new light for picture to show, how to do it
Toshiba LCD 2009 TV picture won't show when turned on but sound works fine. Picture shows after 4-5 minutes. Help...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | Toshiba Televison & Video
Mitsubishi model wd=65c9 when turned on green light blinks repeatably sound comes on but no picture
The bulb that lights your picture is burned out. Buy a new warranted bulb from shopjimmy.com $85 with the housing. You can replace this yourself in 5 minutes. Shop jimmy has a video showing replacement. Remove 2 screws that hold the housing in place, slide the bulb out and slide the new bulb with housing in and replace the 2 screws. Plug in and enjoy your tv.
Feb 23, 2013 | Mitsubishi Televison & Video
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
No picture
Hit F2 to brighten the screen. No picture could be any one of these things you need to buy.
1. New inverter board
2. New LCD backlight
3. New power board/sound board
4. New Logic board
If the parts and repair labor becomes cost prohibitive, then look into a new laptop, unless your handy and can replace the parts yourself.
Mar 23, 2010 | Apple MacBook Mac Notebook
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Sep 27, 2009 | Philips 50PFP5332D 50 in. Plasma...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
The indicator light showed our 51" vivitek projection tv needed a new bulb. We bought and installed a new one - now there is no picture. The bulb is working - but still no picture.
when you replace the door, after you have reinstalled the lamp, make sure that the button inside the television cabinet is being pushed in by the door. i had the same problem when i first replaced my bulb.
Aug 28, 2009 | Vivitek Televison & Video
Tv wont show picture
Got a new tv and didn't pay any online service for a "solution"!
Jan 09, 2009 | Hitachi 50GX30B 50". Rear Projection...
Zenith Z60PV220 60-inch Plasma TV Logo
20 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
