Is the ipod nano 7th gen compatible with the 2011 hyundai sonata via bluetooth
  • 35 Answers
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
Posted on Jan 07, 2008
BAJAN-BOY
  • 66 Answers
SOURCE: Frozen iPod Nano
FOR ALL PERSONS WITH THE FREEZING IPODS AND CANT TURN OFF HERE IS THE SOLUTION
to reset your ipod
switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
rate the solution plzzzz thank u
Posted on Mar 22, 2008
  • 13433 Answers
SOURCE: iPod Nano 3rd Gen
These images might be usefull
http://techrepublic.com.com/2346-13636_11-170826-2.html
http://www.ifixit.com/Guide/iPod/iPod-Nano-3rd-Generation
heres a special tool
http://www.powerbookmedic.com/iPod-Take-Apart-Tool-Set-p-16849.html
Posted on Apr 01, 2008
Bubbabear64
  • 2794 Answers
SOURCE: sleep timer for ipod nano 3rd gen
Go to extras. Select clock. Press enter on you clock settings. Select sleep timer.
Posted on Jun 14, 2008
  • 6 Answers
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
Posted on May 06, 2009
NANO 7TH GEN. WILL NOT PLAY THE PLAYLIST CHOSEN
Sounds like it might have got water/moisture in it.
tryi drying it out.
Sep 07, 2014 | Apple Ipod Nano 16gb Mp3 Player 7th...
How do i delete duplicated photos on ipod Nano 7th gen.?
You'd better cleanup your iTunes library firstly. Just click "View > Show Duplicate Items" and then you would just check off the duplicates that you wanted to remove. After removed all the duplicates in your iTunes, sync it to your iPod, then all duplicates in your iPod will be removed automatically.
Source: http://how-to-delete-duplicates-in-itunes.newgenresoft.com/ How to Delete Duplicates in iTunes 12 11 10 9 automatically
Jun 06, 2014 | Apple iPod nano 7th Generation
Pairing ipod nano 7th generation with plantronics bluetooth headset
Please check the video link provided below for your reference. The device used there is a iphone but the instructions on how to connect a bluetooth headset are the same.
Mar 28, 2014 | Apple iPod nano
Ipod nano 7th gen no sound
I synched to another computer with windows 7 without iTunes on it, it loaded windows drivers (not something you want at all) Next I had no sound, reset it, nothing. Plugged it back into offending computer and went to properties, remove drivers, warning you are about to uninstall this device from your computer. Yes. Sound works again, had to repost.
Jan 12, 2013 | Apple iPod Nano Seventh-Generation
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Cant connect my ex 10 to my x300 head unit
Hi Jared,
The EX-10 was never intended to be an accessory to the IDA-X300, but should work with FM modulation like any other radio, by making sure the FM frequency is set the same on both units. There are four preset channels in the EX-10 but you can change each one to any frequency.
As for the bluetooth mic connection, you must have that connected for the bluetooth to work. You are better off installing a KCE-400BTi handsfree kit to get better functionality, increased phone compatibility, increased audio quality and the ability to use all of the newer iPods (Gen 2 iTouch, Gen 4 Nano and iPhone 3G).
Hope it helps,
Marcel.
Jun 21, 2009 | Alpine eX-10 iPod Controller with...
I got a Philips HTS3555 and i cant get video to play threw the ipod dock. how do i get it to work?
Verify the you are using compatible equipment
Compatible GoGear/iPod devices for playback via the docking station are as follows:
  • iPods from Generation 4 onwards (80GB, 60GB,30GB, 40GB, 20GB, Mini)
  • iPod Nano (Gen 1 & Gen 2 only)
  • Philips GoGear (SA9200/17 only)
if you are still experiencing problems, let me know
Dec 05, 2008 | Audio Players & Recorders
Compatability with 4th gen nano
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Sep 26, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
286 people viewed this question
 Grubhead
Grubhead
