Question about Bosch Benvenuto B20 Espresso & Coffee Maker
Coffe comes out in a longer than usual drip
I have had the machine for somewhere around 3 or 4 years, making all the cleaning processes as demanded by the machine with original Bosch cleaning tablets.
Just today I noticed that the flow of coffee coming from the spouts is not a regular drip that stops instantly once completed, but rather drips in a thin and longer than usual drip.
Would seem like the inner conducts or the spouts themselves are obstructed by something; I would willingly attempt to disassemble the machine in order to clean it, but I don not dare without a disassembly schematic.
Any hints???
Thanks!
  • Anonymous Feb 26, 2009
    Same exact problem
  • 7 Answers
See my B30-solution; same procedure!
http://www.fixya.com/support/t2900087-bosch_benvenuto_tkn68e75_coffee_maker
Posted on Sep 11, 2009
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Jun 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
No brewing
probley needs cleaned! i use a 50/50 mixture of white vinegar and distilled water. run the machine as you would if making coffee. may have to repeat the process a few times.remember after cleaning to run a few cycles of clean water to clear the system
Dec 05, 2007 | Gaggia Espresso De Luxe Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Bosch Benvenuto B20 Espresso & Coffee Maker Logo
821 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
