Question about Gateway FPD1760 17" LCD Monitor
Gateway FPD1760TFT LCD monitor
When I turn my computer on I hear fans running, then the monitor says"no signal". Nothing happens on the monitor and the computer will not boot up, even thought I keep hearing the fan sounds.
If I keep trying sometimes it will boot up, but for 2 days now all I get is the "no signal" on the monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Posted on May 25, 2009
My monitor won't turn on. The computer recognizes it, and the standby light on the monitor blinks, but nothing happens when I push the power button.
When you press power and the Gateway logo does not show, you have a power supply problem. The cause is bad capacitors that sometimes bulge at the top indicating they are open, repairs can run high so careful consideration should be given when moving ahead, also! it is a good idea to check the inverter board for bad caps. "common problem"
Mar 08, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
My monitor just died. no picture no nothing. whats going on is it fixable or thats all i'm going to get from it.
franccoperez
I would try your monitor on another computer to see if it works and/or try a CRT monitor on your computer and reinstall the video card drivers. I have seen a big issue with this lately where the video card drivers are getting corupted. When this happens the computer sends a signal out of range to the monitor causing it to turn off so it does not get damaged.
If your monitor does work on another computer and you need help reinstalling your video card drivers let me know.
Issken
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
I have a Gateway FPD1760TFT LCD color monitor. I
What is the display resolution you have set in your display properties? For this monitor it should be set to 1280x1024 pixels, which should give you proper screen geometry.
Jan 24, 2010 | Gateway FPD1760 17" LCD Monitor
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Monitor will not stay on
please try another set of cables ...... borrow ... to eliminate those ....let me know
May 30, 2009 | Gateway FPD1975W 19" LCD Monitor
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Gateway FPD1760 17" LCD Monitor Logo
347 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
