Question about Toshiba Computers & Internet
How do I get my back arrow back - Toshiba Computers & Internet
  • Toshiba Master
  • 7,627 Answers
Walk to where arrow landed? I would reboot, unplug from AC, remove battery, plug into AC, boot normally.
Posted on Dec 08, 2012
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
I need tray 2 to be the default setting for this printer. It always reverts back to tray 1 everytime I try to print.
Paper Handling Issue -
Hit Menu
Arrow down to Paper Handling and hit the green check
hit the green arrow to go into Tray 1 size - arrow down to envlope #10 hit the green arrow to save
arrow down
hit the green arrow to go into Tray 1 type - arrow down to envlope hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 size - arrow down to letter/legal (depends on what your using) hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 type - arrow down to plain (assume that your using plain paper) hit the green arrow to save
also pull out the paper tray and confirm the guides (where you can adjust from letter to legal etc)
is set correctly.
That should take care of it unless the document you are tring to print is a different type of paper size.
Oct 19, 2010 | HP LaserJet P3005n Printer
How do i change my vw 2.5 trans fluid. and how much would it cost. Because my gears are getting ruff . i have 81000 miles. what should i do ..........please i need some help
Fluid - M/T: Service and Repair
Transmission Oil, Draining
Transmission oil, draining
To catch gear oil, use a clean container with 3.0 liter capacity with a scale.
^ Shift rod is secured.
66e891f.jpg - Drain gear oil by removing oil drain plug - arrow 1 - and then pivot pin - arrow 2 -.
- Install pivot pin - arrow 2 - with a new O-ring
- Screw in oil drain plug - arrow 1 -.
24c9af8.jpg - Now rotate bracket - A - back into initial position in direction of - arrow - so that shift rod moves freely again.
Transmission Oil, Filling
Transmission oil, filling 04A, 5 Speed M/T
Top off gear oil quantity in container to 1.7 liters.
6d27665.jpg - Remove switch for Back-Up Light Switch F4 - arrow -.
- Connect a standard hose (approximately 600 mm long, outer circumference 10 mm) with funnel.
- Insert hose into mounting hole of back-up light switch (2nd technician) and fill the transmission oil.
- Reinstall switch for Back-Up Light Switch F4 - arrow -.
- Check function of selector mechanism.
- Install complete air filter housing.
- Install noise insulation.
Oct 01, 2009 | 2006 Volkswagen Jetta
My key wont go back on
maybe you put the arrows wrong and the up key is in different direction actually, take off all the arrow keys and try each of them as up arrow.
Mar 28, 2009 | Advent 4211c Notebook
HP 4300n prints off the right margin
You possiblely have a font set wrong in your printer. Push the green check button, arrow down to printing, push the check button again, arrow down to PCL and push the green check button again. Arrow down to Font Source, push check button again and check setting, should be internal. Push the left arrow button till you get back to Font Source and down arrow key to Font Number, all ours are set to 3. Left arrow key back to Font Number and down arrow again to Font Point Size, all of ours are set to 12.00. To get back to ready, uset the left arrow key.
If this is all correct, then it has to be in your software.
Mar 05, 2009 | HP LaserJet 4300n Printer
How do you turn on the ram disk
On the printer
Press Menu
Press down arrow until Configure Press right arrow
press down arrow until Maintenance Press right arrow
press down arrow until Init NVRAM Press right arrow
it will ask are you sure?
press middle button (Enter)
Turn printer off and back on to reboot - this should initialize
Dec 14, 2008 | Dell 5100cn Laser Printer
Laser jet 2600n
On the contrary, the 2600N does have a way to override. Press the check button and the right arrow button in this combination:
check, arrow, check, arrow, arrow, check, arrow, check, arrow, check, check.
This should bring you back to the ready screen after a brief pause. This will engage "Override Out". Repeat the check arrow steps in the same sequence to put it back to "Stop Out".
Jerry
Sep 08, 2008 | HP Color LaserJet 2600n Printer
No picture
Try changing the settings back to factory default. Both of my surround speakers stopped working, and doing this brought them back. If your remote functions properly, it can be done by hitting this exact sequence when in the DVD mode:
Setup>Right Arrow>Right Arrow>Right Arrow>Right Arrow>Enter>Down Arrow>Down Arrow>Enter
Note: The Arrow buttons are the ones that surround the Enter button.
This is a very poorly designed system, and the remote will not work from slight angles. You must be directly in front of the unit for the best signal reception from the remote.
Aug 23, 2008 | Curtis DVD6041 System
Computers & Internet Logo
12 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
