Question about SMC EZ Connect SMC2662W V.3 802.11b Wireless Adapter
My computer will not recognize my wireless adapter is pulgged in
I had a modem directly plugged into this computer but am trying to use the modm in another room and put a wireless adapter on it.
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
I do not have an external modem on my computer, it is on the inside. the router will not recognize the modem and vise verce so it will never complete the install of the drivers and such. I use satellite...
Can you do a drawing of what you are doing?
What was your setup before this problem?
Are you installing the Belkin router to provide wireless access to other devices??
Can you be more specific of what you need?
Based on what you wrote..
You have an ethernet card on the desktop PC.
The router usually has 4 ports for connecting devices and one port for connecting the incoming internet connection.
You need to plug first the ISP cable to the Router on the port specially for it and the other 4 goes to any computer.
Check if the cables are OK by connecting them directly to the computer from the wall. If there is internet on both cables, then you need to work on the router.
Check the user manual to setup the router. There is usually a CD which will help you with this otherwise, you will use the manual IP method.
Hope it helps.
Feb 05, 2011 | Belkin (F5D5231-4) Router
Wrt54gx4 was working and now cannot get a connection between the router and dsl modem. have tried to find new netware but cannot get it to download. Have heard linksys has had a lot of this type of...
A simple solution is to plug your modem in to the lan port of your router. A complex solution is to change your lan ip address different then the modem ip address. For example my lan ip for my modm is 192.168,1,1 and my router is 192.168.9.1.
Nov 20, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
I want to not be wireless anymore want to go direct hook up
Take whichever cable/wire that runs from your modem, that should be the first electronic device in the line from your incoming internet service, that would be the main line from whatever your source is be it phone line, cable, or satellite. Plug into the appropiate jack on the back of the computer.
Main incoming line/cable, ----->modem,-------> ethernet cable-------
---------->computer
Nov 27, 2008 | Belkin Pre-N (F5D8230-4) (DBF5D82304)...
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Wireless LAN low speed
Try plugging the computer directly on your modem/router then check your speed. If the speed improves then big possibility that it's the wireless adapter. Try uninstalling then installing it again. If the speed did not change even though you directly plugged it then it means that your computer has a problem. You may need to optimize your IE or disable any firewall or any programs that uses the internet.
Mar 29, 2008 | Computers & Internet
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
Wireless adapter not recognizing IP address
Try pressing and holding the reset button in for 15 seconds and unplugging the power cable and plugging it back in. That should reset the router to factory settings. It can also be done through the router's web interface.
Nov 02, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
SMC EZ Connect SMC2662W V.3 802.11b Wireless Adapter Logo
35 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
