Question about Sony PlayStation 2 (PS2) Console
Disc won't spin
I have got PS2 SCPH-30002 and when I turn it on everything works but ehen i put a disc in it wont spin. I had it openned and the laser head tries to read the disc then the disc moves by less then quarter of the circle and thats it. On the tv it shows the browsing screen and id doesnt even detect the disc. Is there any way how to repair it? I tried to cleen everything with no difference. I am not sure but i think that the previous owner tried to repair it because there were some screw covers missing and also the serial number was scratched out... Thanx
    Scholar:
  • 35 Answers
I hate to be the bearer or bad tidings, but it sounds like the previous owner tried to repair the DVD tray and failed. You might want to take the unit apart and see if there are any internal screws missing. If there are any missing, it can definitely cause issues with the spin up on the DVD tray. If everything is intact, you may have to replace the DVD tray. Hope this helps. Good luck.
Posted on Jun 29, 2007
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
PS2 model # SCPH-70012 Disc will not spin and read the disc... How to fix it?
You need to replace the laser module. Get a replacement online or on ebay, swap it. that's it.
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
Disc wont spin
There are 4 reasons a disc won't spin on the Slim PSP. The most common is a failed laser.
1. Failed laser -- the disc will not spin up to speed, or not spin at all, due to a bad laser. If you close the PS2 with no disc inside, the ps2 will never spin the disc. If you chose the PS2 with a disc inside but a bad laser, it still thinks no disc is inside and will not spin.
2. Lid closed sensors. There are two of them. One on the motherboard and one on the reset switch. These sensors let the PS2 know that the lid is closed. If one or both of these break, the disc will never spin because the PS2 will think the lid is still open.
3. Damaged case. If the case of the PS2 is damaged, the two parts of the lid that are supposed to press the lid-closed sensors will never press them.
For more information, pictures, and parts, click into the following page:
http://store.richspsxparts.com/slpsnospdi1a.html
Oct 21, 2009 | Sony PlayStation 2 Slimline Console
Ps2 disc wont spin and laser wont come on
it seems there has been a malfunction within your CD Drive, this is what is causing the CD drive to not spin or read the disc. these problems can be only generally resolved by either getting the console repaired/replaced unfortunately.
The PS2 will still turn on and run because the CD Drive does not dictate whether the console works or not, but because the CD Drive is broken, you will not be able to play games or watch DVD Films unless you have the CD Drive Repaired.
Hope this Helps ?!
Oct 27, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
You have to have take your station apart and clean the eye... If u need to know how to do it without messing it up email me bak...
Mar 14, 2008 | Sony PlayStation 2 (PS2) Console
My Sony PlaySatation2 console wont read any games on PS2 discs.
Check this web site out, this will help you, this problem happens alot so dont worry you should be able to do it yourself. http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Mar 12, 2008 | Sony PlayStation 2 (PS2) Console
Sonyplaystation2 model scph 70002
Check you 1st posting and please check Solved on this one. The solution I placed on your first posting will work. You gave me a Almost there vote on the last posting and it cut my rating. You cannot change it. By Clicking solved on this one will counter your almost there vote.
Nov 09, 2007 | Sony PlayStation 2 Slimline Console
Ps2 disc wont spin
try loosening the screw to the left of the laser i believe its a torx bit.( i just used a very small flathead). on my broken scph 30001 i used to have to manuallly spin the disk for it to read games so i loosened that screw and lubricated all the tracks with wheel bearing grease(white lithium would be better but i work on cars so it's what i had.
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
192 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
