Numeric ups 600 is not functioning
My ups is not working even for 5 sec when the power shut down what is the problem?
  • 32,281 Answers
The battery maybe worn out and needs replacing.
Posted on Dec 07, 2012
3 Suggested Answers
  • 44 Answers
SOURCE: my acer laptop wont charge up
I wouldn't go soldering anything to your motherboard, first of all. There are WAY too many things packed too tightly together on laptop motherboards to be doing that, unless you work on laptops everyday.
With the Aspire 5315 laptops made by Acer (the most common I've seen), the cooling fan is right by the power jack, so all the heat being put off by your CPU is being blown right onto the power adapter. Enough consistent heat can cause a short in just about any wiring, and the Acer brand is known for using materials that have a slightly high failure rate than others. If the ground shorts into the hotwire, you will not have a green light on the adapter. If, however, the adapter is simply not grounding at all (say, the ground has become disconnected but isn't touching anything that is getting electricity), your green light that says your adapter is find will come on, but your laptop won't charge or power-up (it requires both a ground and a hotwire).
So, diagnosis? I would think that your ground has become disconnected, most likely in the jack itself, since that's where most of the heat is (on the common Acers, anyway). That's a tricky soldering job, but I've done it before. That's actually how I powered mine back up before finally shelling out the bucks to buy a new one. Simplest solution is to buy a new power adapter. Once again, it's best not to go soldering anything to your motherboard.
Hope that helps. :)
Posted on Sep 08, 2009
  • 17 Answers
SOURCE: my pc is getting shutting down after 5 sec.
Open It in safe mod and than Remove all stat up program.........r
Posted on Mar 19, 2010
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
Installed new Gigabyte GA-P67A-UD7 mother board. Have checked the connections numerous times. It starts up and then shuts down in about a sec. I even unplugged the 8 pin 12 v connector to try and locate...
When mounting a motherboard to the case you need to add some spacers between them so the MB doesn't contact the case directly, most the MBs today have a protection to shut down so they don't get burned
Try starting your computer outside the case (you can use a key or a screwdriver for the power pins to start it).
Feb 14, 2011 | Intel Motherboard
My cpu is not shutting down even i shut down. But my monitor showing shuttingdown and display is turning off as if like the system is shut down Still cpu is running. and also my monitor is not turning on...
Shut down by holding in Power button for 5 secs... press F8 continuously on start up, go into Safe Mode with Networking.. have a look around at some of the Devices in Device Manager, check Drivers, also default to normal mode in Bios/Uefi
Aug 13, 2017 | ASUS M2N-MX Motherboard
The ups is shutting down immediatly ,once the AC power is off
thats a dead UPS... battery is bad now... you probably need to have it changed...
Jul 09, 2009 | QVS NetStar (UPS650A) UPS System
My Soyo Free Styler 600 bluetooth headset did not come with instructions, how do you get it to work with the blackberry curve?
on the soyo freestyle 600 you have to power on the device (hold power for about 5 sec) then hold either the volume up or volume down button, I forget, for another 5 sec it should go into pairing mode (Blue-->Red flashing) youre blackberry should b in search mode for bluetooth devices at this point. Then youre blackberry will recognize the device and ask for a passkey (0000 default) registration will be complete at this point once the blackberry recognizes the headset..
Jun 13, 2009 | Soyo FreeStyler 600 Wireless Headset
Powermust 600 USB 5 minutes shuting down problem
Load is the problem. Too low load on UPS will cause that on almost all Musteks.
Dec 12, 2008 | Mustek UPS 600 (POWERMUST600USB) UPS...
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Oct 28, 2008 | InFocus LP 600 Multimedia Projector
AcerPower 1000-EA380M No Video
open the cover,try to find jumper "c-mos clear",probably is green,or red. put it on,then power on the machine abaut 3 -5 sec.then shut it down. then put the jumper in prevoius position and start macine normaly.on screen you have a note "c-mos clear,enter setup......",enter set up and chose auto configuration,save and exit and everything is ok.
Feb 04, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Shuts off about 5 sec. after i turn it on
The power amp module ( s) have probably "bought the farm"
Post what part numbers you find on them.
Jan 05, 2007 | Harman Kardon AVR 510 Receiver
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
